Pietenpol-List: Got some Piet building done today!
Posted: Mon Dec 03, 2012 1:58 pm
Original Posted By: "Kyle85"
John wrote-"I'm looking for the best prop configuration for a Lycoming C1B 0235 powered Piet.I'm looking for dimensions and pitch numbers for best climb performance andany templates and gauges I might be able to borrow through this process. I havebeen considering a 72X44 but if there's a better one out there I would preferto use that configuration"Here's some info from my prop guru:"The older 7ECA Citabrias used the C1 Series O-235. I would look at what they usedfor a prop, then probably go 2" flatter in pitch as the Piet is slightly slowerand draggier than the Citabria (although the 7ECA is pretty much a dog)."--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Got some Piet building done today!
Posted: Mon Dec 03, 2012 2:19 pm
Well, 2 years ago I figured I should be half done with my Piet by now...I wishthat were the case. I suppose moving, having MORE kids and changing jobs havekept me distracted. Part of me wants to say the heck with it and sell the project.(notthat it is much of a project lol) BUT since I was 14 working at an airportwhere experimental aviation was very much alive, I vowed that one day Iwill build and fly my own airplane. So today I snuck away for a few hours to continuemy quest! Pictures to follow.-Kyle--------Airspeed, altitude or brains: Two are always needed to successfully complete theflight.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Pietenpol-List: Re: Got some Piet building done today!
Posted: Mon Dec 03, 2012 9:48 pm
Jake your plane is looking great!!! I found a book that is great to use with thesteel fuselage, it shows all the different mounts and pieces you need on a plane,fromengine mounts to landing gear, you name it. It also has most of thecharts you need like an hardware numbers and measurements. The book is AircraftDetail Design Manual. It is published by Aviation Publications 217E WashingtonSt. Appleton,Wisconsin 54912-0357. I think I got it at the EAA museum. I promiseto get some pictures soon.--------Building steel fuselage aircamper.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Got some Piet building done today!
Pietenpol-List: Re: AN5820-1 turn & bank
Posted: Mon Dec 03, 2012 10:08 pm
I encourage you to keep up the passion.... It's been said to do something - nomatter how small - every day and sooner or later it will be done.... It's thejourney that is the best for me - the small gratifying steps along the way.....--------Jake Schultz - curator,Newport Way Air Museum (OK, it's just my home)Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: AN5820-1 turn & bank
Posted: Mon Dec 03, 2012 11:02 pm
Original Posted By: Bkemike
Never mind... I sat down with the box full of parts and started figuring them out.Turns out that there's only one way the instrument can go back together ;o)--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
