Pietenpol-List: Horns Redone
Posted: Sun Jan 13, 2013 12:57 pm
Original Posted By: DOUGLAS BLACKBURN
Much better this time around. 7 hours stripping old powder coat and prepping for this coat...DQoNCg0KU2VudCBmcm9tIG15IGlQYWQNCkphY2sgVGV4dG9y________________________________________________________________________________
Pietenpol-List: Re: Horns Redone
Posted: Sun Jan 13, 2013 2:32 pm
For information, incase those w/Cont engines are interested:I've been looking to replace my oil temp & pressure gauges in the GN-1, as theoil temp gauge I have was never the correct range scale, and my pressure gaugeis cracked and dinged up. I was never quite satisfied w/my searches. I came closeto what I'd like w/Stewart Warner gauges, but still no joy. I preferred the270 deg sweep of the older antique gauges with no label clutter (basic labeling).I began to think none were out there until I was walking around an oldWW2 museum north of Luxembourg in Diekirch. I looked at the panel in the old Jeepsand "bingo!".. they appear to be the perfect range scale for Continentals.You can get them at any Jeep restorer's website. standard 2" mechanical gauges...LarryRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/imag ... ___Subject: Pietenpol-List: Re: Horns Redone
Re: Pietenpol-List: Pietepol fuse, rib, and tailgroup wood
Posted: Sun Jan 13, 2013 3:24 pm
Original Posted By: Amsafetyc
Doug,First, I am sorry to hear this. I guess it's a point in our lives that we reach at some point.I am interested in all, and can pick up by this weekend. My Piet is done, but am starting another project, which will be Corvair powered, too. I live in N. Calif, but can easily make the drive.Gary BootheSent from my iPhoneOn Jan 13, 2013, at 11:07 AM, DOUGLAS BLACKBURN wrote:> Hey folks,> I was on the list a few years ago, and have been unsubscribed for some time. I was never able to really get started due to health issues my wife has. > > I am only on to let you know I need to get rid of my project. I have the wood for the fuse, wing ribs, and tail group. It is all Spruce. I got most all of it from Carl Levkin, who was, and still may be a member here. He gave me the wood for the tail group. Carl also gave me the the wood for the fuse for a donation to his EAA chapter, in Compton. He cut the wood up for me for the fuse, and cut the stringers to be laminated. He said this would be stronger. Anyway, I believe I donated 75.00 bucks to the Compton EAA group for the fuse wood.I bought the wood for the ribs from a member here for I think around 100.00, and I would like to pass this on to someone who might have the time and where withall to use for they're project. Carl was way kind to me while we were in communication, and I would like to further his kindness to someone else, pay ot forward so to speak!!> > I will take 100.00 for the fuse wood, and also have a Corvair engine I was going to retrofit for this plane as well. The engine is all apart, but Carl had my shaft drilled and tapped for the safety shaft needed to install the prop and adapter for same. I am moving, and need to find a home for this stuff, hopefully someone who will use it. 100.00 bucks gets it all. As I said, I don't know if Carl is still around, if he is and some here know him, give him my regards, he was a fine man. I wish I could have done him right by getting the Piet built, but reallity says it is not to be. I also have a wing rib Jib that a Gent from Down San Diego way gave me. I remeber his name as Gene, and I believe right before I unsubscribed from this list, he got his airworthiness Cetificate for his Piet. I contacted him to see if he wanted the jib back but don't think I ever heard back from him. If he is still on this list, the jib is his, if not, it will be part of the deal here for a hundred bucks. Please take me up on this deal, but only if you intend on using the material to build a Piet. I am moving and it needs to go by the 21st of January. Thanks,> > Doug Blackburn, Yucaipa California> nine oh nine - seven nine zero - zero five three zero home phone, call untill 10:00 p.m.> > P.S. I won't ship, don't have time, so work something out with someone here on the West Coast if you are interested, it really needs to be gone in two weeks. > > Doug/Elizabeth Blackburn Yucaipa California ISR Rocks www.inlandsloperebels.com> > ============================================================================================================================================> ________________________________________________________________________________Subject: Re: Pietenpol-List: Pietepol fuse, rib, and tailgroup wood
Wow, now that's LIGHT material.....it floats!John--------John FrancisRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Pietepol fuse, rib, and tailgroup wood
Posted: Sun Jan 13, 2013 3:43 pm
I met Carl about 5 years ago when Markle and I visited his hangar, a really nice person and a great builder. I've not heard from him since. Does anyone know anything about him?JohnSent from my iPhoneOn Jan 13, 2013, at 2:07 PM, DOUGLAS BLACKBURN wrote:> Hey folks,> I was on the list a few years ago, and have been unsubscribed for some time. I was never able to really get started due to health issues my wife has. > > I am only on to let you know I need to get rid of my project. I have the wood for the fuse, wing ribs, and tail group. It is all Spruce. I got most all of it from Carl Levkin, who was, and still may be a member here. He gave me the wood for the tail group. Carl also gave me the the wood for the fuse for a donation to his EAA chapter, in Compton. He cut the wood up for me for the fuse, and cut the stringers to be laminated. He said this would be stronger. Anyway, I believe I donated 75.00 bucks to the Compton EAA group for the fuse wood.I bought the wood for the ribs from a member here for I think around 100.00, and I would like to pass this on to someone who might have the time and where withall to use for they're project. Carl was way kind to me while we were in communication, and I would like to further his kindness to someone else, pay ot forward so to speak!!> > I will take 100.00 for the fuse wood, and also have a Corvair engine I was going to retrofit for this plane as well. The engine is all apart, but Carl had my shaft drilled and tapped for the safety shaft needed to install the prop and adapter for same. I am moving, and need to find a home for this stuff, hopefully someone who will use it. 100.00 bucks gets it all. As I said, I don't know if Carl is still around, if he is and some here know him, give him my regards, he was a fine man. I wish I could have done him right by getting the Piet built, but reallity says it is not to be. I also have a wing rib Jib that a Gent from Down San Diego way gave me. I remeber his name as Gene, and I believe right before I unsubscribed from this list, he got his airworthiness Cetificate for his Piet. I contacted him to see if he wanted the jib back but don't think I ever heard back from him. If he is still on this list, the jib is his, if not, it will be part of the deal here for a hundred bucks. Please take me up on this deal, but only if you intend on using the material to build a Piet. I am moving and it needs to go by the 21st of January. Thanks,> > Doug Blackburn, Yucaipa California> nine oh nine - seven nine zero - zero five three zero home phone, call untill 10:00 p.m.> > P.S. I won't ship, don't have time, so work something out with someone here on the West Coast if you are interested, it really needs to be gone in two weeks. > > Doug/Elizabeth Blackburn Yucaipa California ISR Rocks www.inlandsloperebels.com> > ============================================================================================================================================> ________________________________________________________________________________
RE: Pietenpol-List: Horns Redone
Posted: Sun Jan 13, 2013 4:31 pm
Looking good Jack. Better hurry and install them if you're going to fly itto Brodhead this summer. Looks like there will be several new Piets therethis year.Jack PhillipsNX899JPSmith Mountain Lake, Virginia-----Original Message-----
Posted: Sun Jan 13, 2013 5:23 pm
Huh?.............. Gary Boothe what is your next Corvair-powered endevour? Share it with us bro!Dan HelsperPuryear, TN-----Original Message-----
Re: Pietenpol-List: Horns Redone
Posted: Sun Jan 13, 2013 5:26 pm
Original Posted By: Jack T. Textor
Is that black??Dan HelsperPuryear, TN-----Original Message-----
RE: Pietenpol-List: Pietepol fuse, rib, and tailgroup wood
Posted: Sun Jan 13, 2013 6:03 pm
Didn't mean for that to hit the Pietenpol List! I have the plans for aBoredom Fighter.Gary BootheNX308MB
Original Posted By:> Jack T. Textor
A special shade of black...Sent from my iPadJack TextorOn Jan 13, 2013, at 5:26 PM, helspersew(at)aol.com wrote:> Is that black??> > Dan Helsper> Puryear, TN> -----Original Message-----
Posted: Sun Jan 13, 2013 6:05 pm
Boy I wish I could Jack, at this stage the progress slows to a crawl...Sent from my iPadJack TextorOn Jan 13, 2013, at 4:31 PM, "Jack Phillips" wrote:> > Looking good Jack. Better hurry and install them if you're going to fly it> to Brodhead this summer. Looks like there will be several new Piets there> this year.> > Jack Phillips> NX899JP> Smith Mountain Lake, Virginia> > -----Original Message-----
Posted: Mon Jan 14, 2013 6:22 am
Original Posted By: "Jack"
Tell me about it! Seems that I work and work and nothing gets done! Chuck----- Original Message -----
Posted: Mon Jan 14, 2013 6:26 am
Gary, I corresponded with a guy who put a Corvair in a Boredom Fighter. He says it's fine but you have to fly it every minute. He said that the engine had to practically butt against the firewall for it to be in balance. I really wanted to build the Boredom Fighter but had already bought the Piet plans so decided on the Piet. Chuck ----- Original Message -----
Posted: Mon Jan 14, 2013 7:35 am
