Re: Pietenpol-List: Steel Parts Again
Posted: Sun Jan 20, 2013 8:05 am
Subject: Pietenpol-List: Re: Cross wind component> > Rod,> > Has your chosen test pilot done much work in that area? I have done some PostMaintenance test flying in my past life (Not the same as testing a Piet, > but many concepts are the same). My goal in testing was to keep the > variables to a minimum, so you are learning, testing, and checking > one thing at a time. Too many variables skews the results.> > My suggestion is calm wind to slight wind day for those first test > flights. It makes it much easier to figure out if the airplane is > rigged right when you are having to fly or land in a crab. He > shouldn't even be concerned as to what a Piet is capable of at this > point. I hope his question was general in nature and not what he > was going to try and do in the test phase.> > My 1.5 cents> > --------> Semper Fi,> > Terry Hand> Athens, GA> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 748#392748> > > > > > > > > > ________________________________________________________________________________Subject: Re: Pietenpol-List: Steel Parts Again
