Pietenpol-List: Front seat flying, pax in rear
Posted: Fri Feb 15, 2013 4:01 pm
Original Posted By: "tools"
Subject: Pietenpol-List: Re: Am I building the wrong airplane? (Pilot Weight Again)> > Well, the one thing we can all agree on is that no two Piets will have the sameweight & balance, so sweeping generalities about maximum pilot > weight are just BS. However, here's another data point based on my > airplane. Scout has an A75 on the nose (same weight as an A65), > empty weight of 633 lbs., 4" swept-back cabanes, and a 16 gallon > fuel tank in the nose. I believe it's the 'improved' fuselage > length. Pretty stock.> > The spreadsheet shows that will full fuel and oil, the heaviest > pilot that can saddle up in the rear cockpit is about 215-220 lbs. > and although the airplane will still be under gross by 144 lbs., > the CG will be at the aft limit.> > With that loading, I can put a 144 lb. passenger in the front > cockpit and the CG stays about the same but I'm at gross. The > airplane has flown many times in that configuration and is quite > happy, but climb rate isn't spectacular.> > The other things to check (and Tools touched on this) are minimum > pilot weight and front-seat solo. My airplane has a minimum pilot > weight of 105 lbs (rear cockpit), because with full fuel and oil, > the CG falls out the front end of the envelope with a too-light > pilot, even though the airplane is only at 839 lbs. gross that way. > My airplane can also not be safely soloed from the front cockpit > for the same reason, so the front cockpit is placarded against > front seat solo flight.> > Get the W&B spreadsheet and play with it. Mine is attached, if > anyone cares to tailor it to their own airplane and use it as a > template.> --------> Oscar Zuniga> Medford, OR> Air Camper NX41CC "Scout"> A75 power> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 383#394383> > > > > Attachments: > > http://forums.matronics.com//files/nx41 ... 10_155.xls> > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Front seat flying, pax in rear
