Pietenpol-List: Here's the picture titled "Into the barn it goes"
Posted: Mon Mar 25, 2013 8:16 pm
Original Posted By: "Charles Burkholder"
________________________________________________________________________________
Re: Pietenpol-List: Here's the picture titled "Into the barn it goes"
Posted: Mon Mar 25, 2013 8:20 pm
Ok full power.... keep that nose going straight with right rudder. Ok tails coming up and wires are singing. Should be ready to...........Ok maybe in a year I can be doing that for real...CB________________________________________________________________________________Subject: Re: Pietenpol-List: Here's the picture titled "Into the barn it goes"
Posted: Mon Mar 25, 2013 8:21 pm
That's as far as Bill could toss it?GarySent from my iPhoneOn Mar 25, 2013, at 6:16 PM, "Charles Burkholder" wrote:> > ________________________________________________________________________________Date: Mon, 25 Mar 2013 19:22:35 -0600Subject: Re: Pietenpol-List: Here's the picture titled "Into the barn it goes"
Posted: Mon Mar 25, 2013 8:30 pm
Right!! Actually this is back at my place and my cousin is holding it while I run upstairs to pull it up! Picture copyright is free so put it in any magazine or website or calender you want!!!cb ----- Original Message -----
Pietenpol-List: Re: Here's the picture titled "Into the barn it goes"
Posted: Mon Mar 25, 2013 9:23 pm
That's the new EXTREMELY light dacron on the wing.Great photo.Bill C.Read this topic online here:
Re: Pietenpol-List: Chris Tracy's Progress
Posted: Mon Mar 25, 2013 9:45 pm
Original Posted By:> "Ray Krause"
I plan to be there with lots of questions and oohs and aaaaws about you plane and covering. Sounds exciting!RaySent from my iPadOn Mar 25, 2013, at 3:10 PM, gboothe5(at)comcast.net wrote:> Ray,> > What Jim said about bonding to varnish....> > Fire up that little hot rod of yours, and fly over this Saturday morning. I'm in B6, on the far south side still...> > Gary>
Posted: Mon Mar 25, 2013 9:52 pm
Thanks or all the responses about covering. When I planned on going o the EEA Fabric workshop, I did not realize they would only be speaking about the Poly-Fiber system. I felt a little bad about being there and knowing I would not be using their system. When he said their Poly-tak required the two part epoxy primer on the wood/fabric contact areas, I knew it was not for me! It is bad enough just varnishing the damn wings.Hope to meet up with Gary this weekend.RaySent from my iPadOn Mar 25, 2013, at 2:35 PM, Jim Boyer wrote:> It works fine Ray also the glue works fine gluing fabric to the wood. No need to use special epoxy primer first.> > It is much nicer to use than the poly fiber process as far as smell and toxicity of chemicals used.> > Cheers,> > Jim> > > > > > ============================================================================================================================================> ________________________________________________________________________________
Posted: Mon Mar 25, 2013 9:54 pm
Original Posted By:>>> owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-
Thanks, Jack.I have already sanded most of the wing parts that will contact the fabric; at least on the left wing. Sanding and painting are two different things.Thanks again,RaySent from my iPadOn Mar 25, 2013, at 2:11 PM, Jack wrote:> Yes it does Ray but I suggest a good sanding...> > Sent from my iPad> Jack Textor> > On Mar 25, 2013, at 3:35 PM, Ray Krause wrote:> >> Thanks, Gary. Then that is what I will do. You must have used exterior paint with UV protection? What primer did you use, UV protection there, too? So no silver coats? Does the Eco bond stickum work right on the varnished wood? Poly-tac requires that you paint the wood/fabric contact areas with an epoxy primer, YUCK!>> >> Wen will you be to the Lincoln airport again, would still like to fly over for a visit?>> >> Ray>> >> Sent from my iPad>> >> On Mar 25, 2013, at 4:07 AM, "Gary Boothe" wrote:>> >>> Ray,>>> >>> I=99m in the middle of installing the Dan Weseman 5th Bearing on the front of my Corvair, so will be down for a couple more weeks.>>> >>> Light weight fabric is what I used, glued on with Stewarts Eco-Bond and painted with latex primer and paint (Kelly Moore).>>> >>> Gary Boothe>>> NX308MB>>>
Pietenpol-List: Re: Steve from Owings, MD
Posted: Mon Mar 25, 2013 10:48 pm
Original Posted By: "chase143(at)aol.com"
Where do you get that type of fabric?Congratulations. I bet there are a lot of those type of finds out there in lotof barns in the Midwest.I'm really happy for you, saved yourself a lot of work!Ray KrauseSkyScoutSent from my iPadOn Mar 25, 2013, at 7:23 PM, "Bill Church" wrote:> > That's the new EXTREMELY light dacron on the wing.> Great photo.> > Bill C.> > > > > Read this topic online here:> >
http://forums.matronics.com/viewtopic.p ... 059#397059> > > > > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Steve from Owings, MD
