Pietenpol-List: Final assembly!
Posted: Fri Apr 12, 2013 7:54 am
Subject: Re: Pietenpol-List: "Re-PIET" tire changeDouwe, how did you do the muffler/silencer?.. the lenght of the exaust tubeplus the silencer what is it?. and what engine you have? the lenght anddiameter is in relation with the displacement of the engine, isn't it?..RegardsMario Giacummo. -..- .. ... - .. .-. / . ... / ..- -. / .... . -.-. .... --- --..-- /...- .. ...- .. .-. / . ... / ..- -. / .- .-. - .2013/4/9 Douwe Blumberg >> Well, my supercool (to my eye anyway) gray tires started cracking too much> for comfort. Gray rubber is old fashioned natural rubber and being> non-vulcanized, cracks like old fashioned tires did. These kept cracking> along the seam though, so the tire company very kindly exchanged them for a> black set, which won't have any of those problems.>> Just put them on, and it's she kinda looks different.>> Supposed I'll get used to it!>> Douwe>>________________________________________________________________________________Subject: Pietenpol-List: Final assembly!
Re: Pietenpol-List: Final assembly!
Posted: Fri Apr 12, 2013 8:16 am
Everything is going back together nicely..... It's really exciting now--------NX321LRFully AssembledTail assembly and ailerons covered and painted.Wings covered and primed, one paintedMitsubishi PoweredRead this topic online here:
http://forums.matronics.com//files/imag ... ___Subject: Re: Pietenpol-List: Final assembly!
Posted: Fri Apr 12, 2013 8:46 am
Original Posted By: Chris Rusch
Wow Chris, awesome! Very exciting!Dan HelsperPuryear, TN-----Original Message-----
Posted: Fri Apr 12, 2013 8:50 am
Original Posted By: Jack
Subject: Pietenpol-List: Chris Rusch final assemblyChris---what a gorgeous looking airplane you have there! You're the first onewith the olive drab US Army Air Corpspaint scheme that I've seen and it looks great. Your workmanship looks to befirst class. Thank you for sharing some photos. Will your radiator for your Mitsubishi engine be in the traditional Ford A location?Looks like you've adopted or fabricated a gear reduction drive up front. Arethey using these engine in other homebuilts thatyou know of?Great to see your progress!Mike C.________________________________________________________________________________Subject: Re: Pietenpol-List: Final assembly!
Pietenpol-List: Re: Chris Rusch final assembly
Posted: Fri Apr 12, 2013 9:04 am
Wow holy cow Chris looks great!Sent from my iPadJack TextorOn Apr 12, 2013, at 8:16 AM, "Chris Rusch" wrote:> > Everything is going back together nicely..... It's really exciting now> > --------> NX321LR> Fully Assembled> Tail assembly and ailerons covered and painted.> Wings covered and primed, one painted> Mitsubishi Powered> > > > > Read this topic online here:> >
http://forums.matronics.com/viewtopic.p ... 506#398506> > > > > Attachments: > >
http://forums.matronics.com//files/image_734.jpg>
http://forums.matronics.com//files/image_208.jpg> > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Chris Rusch final assembly
Posted: Fri Apr 12, 2013 9:24 am
Original Posted By: Craig Aho
Thanks! I have to say this site has been a huge inspiration to keep pushing forward,i look forward to seeing what everybody is up to and how everyone else solvesthe issues that come up. Nobody has used this engine to my knowledge, it my modern version of a model "A"......wellsee, remember its "Experimental Aviation"The unit up front is a external bearing hub with isolator bushings between thecrank and prop, hopefully removing all of the torsional vibration as well as thrustloads. This unit also houses the starter ring..Im using a harley davidsonstarter and ring gear, spinns it over like butter.I know Jack is painting his a similar green, so i cant wait to see them both together.--------NX321LRFully AssembledTail assembly and ailerons covered and painted.Wings covered and primed, one paintedMitsubishi PoweredRead this topic online here:
Posted: Fri Apr 12, 2013 9:51 am
Original Posted By:> rmdinfo(at)rmdbenders.com
Wow this is awesome=2C man look at the creativity involved=2C the clever anti torque setup and the nice wheels=2C very interesting engine setup=2C the color you chose=2C wow. Ok I need to calm down a bit I'm not the young anymore. Man I have got to get over to Broadhead only I worry the excitment might kill me.
Craig > Subject: Pietenpol-List: Final assembly!
Pietenpol-List: Re: Final assembly!
Posted: Sat Apr 13, 2013 12:13 am
Man that is lookin good. What engine is that? I was wondering if it is a Honda?--------Building steel fuselage aircamper.Read this topic online here:
Pietenpol-List: Re: satellite tracking devices
Original Posted By: "Fun2av8"
> To: pietenpol-list(at)matronics.com> om>> > Everything is going back together nicely..... It's really exciting now> > --------> NX321LR> Fully Assembled> Tail assembly and ailerons covered and painted.> Wings covered and primed=2C one painted> Mitsubishi Powered> > > > > Read this topic online here:> >
http://forums.matronics.com//files/image_208.jpg> > > > ============================================> > > ________________________________________________________________________________Subject: Pietenpol-List: Re: satellite tracking devices
