Pietenpol-List: Control cables through fabric
Posted: Tue Apr 23, 2013 8:36 am
Hello,Yesterday I was measuring where the rudder and elevator cables pass through theimaginary fabric sides on the fuselage. I install the elevator and the rudderand connect the horns one by one to see where I have to make holes dependingon the positin of the plane, up, level, down, right, line left.. and I saw thatthis point vary the positin depending on the palane position. So what do youdo? you make a simple hole in the middle of the line or you cut a line?. I amthinking in a hole in the middle because the lateral forces of the wire cableare minimal and reinforce the only hole with a leader patch. It is the way todo that?.regards.mario--------Mario GiacummoPhotos here: http://goo.gl/wh7M4Little Blog : http://vgmk1.blogspot.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
