Pietenpol-List: Axle bending
Posted: Tue Apr 30, 2013 10:26 am
Subject: Pietenpol-List: Update from: Corky's Rib BuildingPieters,Progress is the word. Jig completed. This is the original design by Mr Pietenpol. Those interested in a set of ribs will have to inform me whether a one piece wing or 3 piece. Choice of 1/2X1/4 or 3/8X1/4 cap strip. The material will be premium selected Douglas Fir from Washington state. Kiln dried,tight vertical grains. A 3/8 width will be much stronger than a 1/2 spruce and near the same weight. All will be 3/8X1/4 unless requested otherwise. T-88 glue used. Also, decide whether you are using 1in or 3/4in spars.If interested parties will respond to this letter I would appreciate it so I might make my plans.Going in Tuesday so they can whittle on my heart a bit. If you don't hear from me by the 8th or 9th then you best start looking for another rib companyCorkyChief honcho ________________________________________________________________________________Subject: Pietenpol-List: Axle bending
