Pietenpol-List: 4130 tubing FOR SALE
Posted: Sat Jun 08, 2013 5:56 pm
Hello all, I have moved on to other airplanes and decided not to continue on withmy Piet project. I have a really nice " Wing Kit " to give someone a nice starton there wings. Everything is spruce and mahogany plywood. I have all theribs built, the spruce spars have all the plywood plates on and holes drilled.Was at the point of starting to to put the ribs on and wings together but neverglued so all the ribs are slid back off. Center section is glued up and allis squared perfect. All holes are right on and all slides right together withperfect fit. Have all the wood to build wings and ailerons. All spruce. Hada wood shop make a cutter and make the leading edge to a smooth rounded edge.Also had trailing edge milled to fit tongue and groove in trailing edge of ribs.All is in a 15' box for easy hauling. Have all Ken Perkins water jet fittingsthat were epoxy primed and painted satin black. Will sell for less than halfof what I have in materials and labor is free. You all know what spruce costand Ken's parts alone are almost work what I am asking. Will sell all for $ 1,500.00and someone would have a jump start on a nice set of wings. All workmanshipis quality. You will not be disappointed. Will try and post some pictureshere. In the pictures the wings are sitting together but not glued. As I saythey are all apart now and everything is in a easy haul-able size. If anyonewould like more pictures or info. email me direct to my email. Thanks Rob 812-932-9000or 812-689-1254Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/ad_p ... ___Subject: Pietenpol-List: 4130 tubing FOR SALE
