Pietenpol-List: Speaking of TGWP....
Posted: Mon Jul 08, 2013 2:59 pm
Original Posted By: "tools"
N2RN simply has the nuts squeezed in there, so there's enough room, just barely.I've been referencing the display bare bones Piet in the Piet hangar as OSHwhile building my tail feathers at Pioneer, it's got access holes cut in thegusset plates.Third idea is what I saw on the hinges of the J1 Standard wing I worked on, ithad the nuts brazed to a plate, which made the whole mess a lot easier to workon. Also, the hinges could be removed for covering. It would prevent you fromhaving to get a wrench in the tight spot on the very outboard hinge bolts.The plate was held in place with brads like those used on the gusset plates. Workedreally well.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Speaking of TGWP....
