Pietenpol-List: Carlson aircraft strut fittings
Posted: Wed Jul 31, 2013 8:49 pm
I've just ordered some strut material from Carlson and I've been surfing the archiveson how the fittings are being made. It appears most folks are using 7075aluminum inserts for the strut ends. I'm wondering why 7075. I understandthe strength is better but really the struts are 6061 so if the fittings aretwice as strong by using 7075, doesn't that just move the failure point to thestrut rather than the fitting? Plus the strut material material area that isin contact with the bolts is much smaller than the area of the insert itself.Is my logic flawed here?I thought I read that the corrosion resistance is better in 6061 but I might bemistaken as I've read a lot on the different alloys today and might have it confusedwith another.Thanks, Tom BrantSent from my iPad________________________________________________________________________________
