Pietenpol-List: Bob's Progress Report
Posted: Mon Sep 02, 2013 11:31 pm
Jack;You nailed it when you described your airplane's climb performance on a warm daywith a load. Most will be similar, but not all. John Dilatush's (now GregBacon's) turbo Subaru-powered Piet was intentionally powered for John's high/hotlocation in Salida, Colorado and could probably maintain a spritely climb rateup to where oxygen would be required (12,500')- which might be pattern altitudein Salida in the middle of a hot summer afternoon ;o)I have never had Scout above 4500' on the altimeter. It took me a while to getup there (over half an hour), and frankly, it was quite chilly up there withjust shorts and a tee shirt on for half an hour. Not only that, I got the feelingthat I was too high up and it was an anxious and worried feeling.I have thought about just how high my airplane could climb, given time and a mixturecontrol, because any sort of flight across the Continental Divide wouldrequire that I traverse some mountain passes or at least cross some fairly highterrain. While I am sure the airplane could do it, I'm also sure that it wouldrequire some fuel, planning, and time. As others have stated about theseairplanes, "Piets are slow, but the sky is patient".--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Bob's Progress Report
