RE: Pietenpol-List: Center section half moon
Posted: Sun Oct 06, 2013 2:05 pm
Several of Mike Cuy'shttp://westcoastpiet.com/images/Mike%20Cuy%20A-65%20Piet/mike_cuy.htmSeveral of Gary Boothe'shttp://westcoastpiet.com/images/Gary%20Boothe/wing.htmJack Textor toohttp://westcoastpiet.com/images/Jack%20Textor/wing.htmRick Holland as wellhttp://westcoastpiet.com/images/Rick%20Holland/pictures.htmThere are more but I don't have time to search for themChrisSacramento, CaWestcoastpiet.com _____
Re: Pietenpol-List: Center section half moon
Posted: Sun Oct 06, 2013 11:21 pm
Original Posted By: tmbrant(at)msn.com
Hi Tom Do you want to see mine, its at my hangar.Dick N. ----- Original Message -----
Hi Tom Do you want to see mine, its at my hangar. Dick N. ----- Original Message -----
Pietenpol-List: Re: Center section half moon
Posted: Mon Oct 07, 2013 6:12 am
Doing a moon cutout reduces wing area, hence why Bernie used the center flap.--------Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Re: Center section half moon
Posted: Mon Oct 07, 2013 6:33 am
But it does increase visibility, particularly during tight turns...Jack PhillipsNX899JPSmith Mountain Lake, Virginia-----Original Message-----
Posted: Mon Oct 07, 2013 11:07 am
The Fuel Tank is in the wing and no aux tank at all.I am going to shim the horizontal stab up in the rear 1/4" and see how tha affectsthe flying characteristics.Thanks for all of the suggestions!taildrags wrote:> Chris;> > With the standard CG envelope being 15"-20" aft of wing leading edge, flyingit with the CG at 15.6" aft is definitely going to be nose heavy. My airplanehas a 16 gallon fuel tank in the nose and when I'm flying solo with full fuel,I have to hold some back stick too. Where is the fuel tank in Two One LimaRomeo? If it's in the nose and you're doing test flights with full fuel, youmight try draining off half the tank and flying it again. And unless it is requiringconsiderable back stick to hold it straight & level, or you have a wingcentersection fuel tank, it doesn't sound like you have any big adjustmentsto make.--------NX321LRNow test flying!!Mitsubishi PoweredRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 7 Oct 2013 10:09:06 -0600Subject: Re: Pietenpol-List: Center section half moon
Posted: Mon Oct 07, 2013 12:17 pm
If a board does not have a finished edge to begin with as you have seem runningit through a table saw will not give a perfect edge. One way is to attach a straightedge to the board being cut so it rides the fence then rip it. This isvery important that the edge be true before ripping pieces from it.Or one would run the edge on a joiner first to true the edge before sawing rippingit. But joiners are expensive. If you want to do it yourself go an purchasea block plane, the longer the plane face the truer the edge will be that youare planing.Watch this: you want a plane that size.Good luck, learn and have fun,WF2--------Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Center section half moon
Posted: Mon Oct 07, 2013 7:00 pm
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________________________________________________________________________________
Posted: Mon Oct 07, 2013 7:04 pm
Original Posted By:> jack(at)bedfordlandings.com
yeah=2C I guess I waffled a bit on whether i'd do the flop or a cutout and this is where I've ended up too. I like the Hybrid flop/cutout idea too=2C but it's too late for me to do that. Cutout it is.Tom B.
Posted: Mon Oct 07, 2013 7:31 pm
Tom No problem call me when you get time. I will be helping Bob Poore for a couple of days but I will be clear after that. It is at my hangar at Cryystal.Dick N651-638-0793 ----- Original Message -----
Re: Pietenpol-List: Felix For Sale
Posted: Mon Oct 07, 2013 7:37 pm
Original Posted By: Jim Boyer
Hi Jim,Thanks, No, no wire. I do tie the scarf through the coat hangar loop in the jacketso it doesn't pull on my neck.Skip----- Original Message -----
Posted: Fri Apr 28, 2017 9:38 pm
> gs.com>> > But it does increase visibility=2C particularly during tight turns...> > Jack Phillips> NX899JP> Smith Mountain Lake=2C Virginia> > -----Original Message-----
