Pietenpol-List: Re: Corvair College 28, 28 Feb - 2 Mar 2014, San Marcos,
Posted: Thu Nov 21, 2013 5:37 pm
Original Posted By: "bdewenter"
I would like to be included on the list and have others contact info. I am planningon building a steel tube fuselage. Have tubing already and plan to starton it in a couple months. Real close to finishing my wings. RobRob StoinoffStoinoff's Restorations56 Progress DriveBatesville, IN 47006812-932-9000www.stoinoff.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Corvair College 28, 28 Feb - 2 Mar 2014, San Marcos,TX
Pietenpol-List: Re: steel tube builder directory
Posted: Thu Nov 21, 2013 6:37 pm
Ken,You might be putting Kevin into a tough spot asking if you should crate up yourengine for a 1,000 mile trip. It really depends on how experienced an enginebuilder you are, and what you might need (tools, parts, experience, knowledge)to make sure your first engine run is a success.Based on my experiences from attending 5 colleges now, I can offer you this:If you are NOT a gear head - If you have an issue during your first engine run, William is there to help- he is very smart! - William brings the setup to pre-oil your engine and to visually ensure oilis flowing from all the rocker assemblies - William will ensure you have set your initial timing. If you did it right(or admit you are not sure) he will show you how to set it / check it at WOT/fulladvance.If you ARE a gear head - If you find an issue at the last minute William has the parts and tools toovercome many common simple first start issuesYou will never regret the fellowship. Along with several others, I continue toattend the colleges in Barnwell because of the people..As to what to bring, or not, William has his standard intake system (intake pipesand carb). If you have a non "WW" standard intake it may be difficult to hookupto his test stand. He provides an exhaust system, battery, fuel, baffle- everything most of us do NOT have when we want to run our engines for the firsttime. It is actually best to use his test stand components as it speedsup the engine test stand usage. I hope this helps. Feel free to opine rdewenter(at)woh.rr.com--------Bob 'Early Builder' DewenterDayton OHRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: steel tube builder directory
Posted: Thu Nov 21, 2013 8:07 pm
Thanks Paul.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 22 Nov 2013 00:19:03 -0800
Posted: Fri Nov 22, 2013 8:18 am
Add me to the steel tube list... just have the tubing at the moment, plan on usingOA welding, working on a shop also. Regards.--------A remarkable lad , capable of many thingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: steel tube builder directory
Posted: Fri Nov 22, 2013 4:28 pm
Roger! Two-Six-Victor-Kilo it is then! Very nice airplane; lots of details toinspect in the photos. I see he has 'cheaters' (brakes) on those big wheels.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Corvair College 28, 28 Feb - 2 Mar 2014, San Marcos,TX
Posted: Tue Jan 07, 2014 10:39 am
Can you try posting the image again Dan? Scott Knowlton Sent from my iPhone> On Jan 7, 2014, at 10:23 AM, "Dan Yocum" wrote:> > > > >> On 01/05/2014 01:00 PM, skipgadd(at)earthlink.net wrote:>> >> Felix the GN1 has a J3 cowl. It has 3 studs attached to the firewall on>> each side, than a piece of leather and lock pins stuck through a hole in>> the stud. There is one on each side similar type stud/lock pins holding top>> to bottom half of cowl. There are 2 studs on eater side of the prop hub.>> They are bolted with a kind of bow tie shaped piece to the engine block.> > N8031 has a similar solution. It's hard to see in this image, but look> closely at the triangular piece of sheet metal with a stud welded to it,> right behind the prop:> > https://plus.google.com/photos/10084355 ... 5002483077> > The triangle is bent offsetting it toward the center line and bolted to> the front 2 cylinder studs.> > >> I always thought it was stock J3, since it has a stock J3 cowl and engine>> mount.>> Bingelis does say #1 page 100 "As a rule the cowling is not attached to the>> engine">> Maybe it works on this plane because there are only 6 attach points cowl to>> firewall and 2 attach points to the engine block.>> Anyway it has worked for almost 500 hours no problem. It is also very easy>> to remove the cowl.> > One of the studs or the triangle pieces work-hardened and broke back in> '09 but it's flown 150+ hours since then with no problems (unless it's> broke since I sold it in '12).> > The holes in the cowl that slip over the studs are strengthened with a> brass grommet, iirc.> > Dan> > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Corvair College 28, 28 Feb - 2 Mar 2014, San Marcos,TX
