Pietenpol-List: tail turnbuckles
Posted: Thu Dec 05, 2013 6:44 am
Hi Ray,In theory turnbuckles are not required for your tail surfaces. In theory,if everything was built perfectly and needed no tweaking and if you couldget the exact tension between all eight wires without turnbuckles, theywould be superfluous.I THINK I've heard of some guys just twisting the cables to make minoradjustments and I personally can see no problem with this; should work fine,assuming you're an accurate builder and you don't introduce too much twistinto the cables.HOWEVER, imho, in the real world, most of us have needed to adjust our tailsurfaces as we've refined things during flight testing and a turnbuckle suremakes it easy.It is very wise to be concerned with every ounce of weight added, as thiskind of thinking will help fight off the "weight monster" that can so easilycreep up on us builders. HOWEVER, I think one should combine weight concernwith an awareness that one is building an airplane for use in the real-worldover a period of decades (hopefully). This means to me that the decision tochuck an item should be made against a backdrop of real-world usage. Yes,weight does add up, but there are some things that are just worth it. Maybeit's a step. maybe it's brakes. . After a year of "living" with RE-PIET, Iam coming to realize that things that encourage maintenance and make hereasier to use are very valuable. Some things are purely optional and havelittle function in making an airplane more "liveable", such as thickerupholstery. Some things add weight but save money but in the end don'treally affect "liveability" such as steel rims over alloy rims. Some thingswill add weight, BUT do add to the "liveability quotient" and these are thethings which should be thought about with the coming decades in mind. Frommy limited experience, some items that fall into this category would beturnbuckles everywhere, a step, a comfy seat, a good fuel gauge, goodbrakes, a harness that is easy to adjust when sitting in that tiny cockpitwith winter clothes on, a well-designed cowling that's easy to get off, withlots of access panels. etc.That all being said, the VAST majority of builders use turnbuckles backthere and I would if I were building again.$.02Douwe________________________________________________________________________________Date: Thu, 5 Dec 2013 05:33:25 -0800 (PST)
Re: Pietenpol-List: tail turnbuckles
Posted: Thu Dec 05, 2013 9:59 pm
Douwe,Thanks so much for the common sense commentary on the use of turnbuckles and other items. I really appreciate your approach to this topic. So far in my building, I have not been too concerned about adding a little extra weight because this is going to be a single place Pietenpol with an A-65. However, I am aware of where the weight might go, I.e. towards the tail. I am also trying to be concerned about drag, to the extent that is possible with a Pietenpol! Having built my Waiex, I know what a "clean airplane" is and what things are critical to this and performance.Also, having just made all the eight cables that hold the mid section on the wing above the cabane struts on the Sky Scout; I know the challenge of making cables to the proper length so the turnbuckles tighten to the right point! I refuse to count up the amount of cable, thimble s and Nicopress fittings I have wasted! But I am getting better.So, the chances of my making cables for the stabilizers so accurately they they require only a couple twists to fit properly is almost Zero! And of course, twisting only shortens the cables, it does not lengthen them!With all of that, I am sure I will be using the 1/16" cable and the eight 6-40 small turnbuckles for the stabilizers.Also, at my age (72), I have added a step, a little extra depth to the cockpit, extra leg room (I am 6'4" tall), and plan on plenty of padding on the seat! There are also extra access panels because I do not bend well! So I am going for comfort, practicality and good flying qualities. Hopefully, the plane will outlast me and may be passed down to my grand children!Thanks for you great comments, I take them seriously! And, by the way, I love RE-PIET, especially the flying pig and the exhaust, not to mention the cowling and wheels. It must be nice to be an artist!Ray KrauseSkyScout abuilding....Sent from my iPad> On Dec 5, 2013, at 4:44 AM, "Douwe Blumberg" wrote:> > Hi Ray,> > In theory turnbuckles are not required for your tail surfaces. In theory, if everything was built perfectly and needed no tweaking and if you could get the exact tension between all eight wires without turnbuckles, they would be superfluous.> > I THINK I=99ve heard of some guys just twisting the cables to make minor adjustments and I personally can see no problem with this; should work fine, assuming you=99re an accurate builder and you don=99t introduce too much twist into the cables.> > HOWEVER, imho, in the real world, most of us have needed to adjust our tail surfaces as we=99ve refined things during flight testing and a turnbuckle sure makes it easy.> > It is very wise to be concerned with every ounce of weight added, as this kind of thinking will help fight off the =9Cweight monster=9D that can so easily creep up on us builders. HOWEVER, I think one should combine weight concern with an awareness that one is building an airplane for use in the real-world over a period of decades (hopefully). This means to me that the decision to chuck an item should be made against a backdrop of real-world usage. Yes, weight does add up, but there are some things that are just worth it. Maybe it=99s a step maybe it=99s brakes . After a year of =9Cliving=9D with RE-PIET, I am coming to realize that things that encourage maintenance and make her easier to use are very valuable. Some things are purely optional and have little function in making an airplane more =9Cliveable=9D, such as thicker upholstery. Some things add weight but save money but in the end don=99t really affect =9Cliveability=9D such as steel rims over alloy rims. Some things will add weight, BUT do add to the =9Cliveability quotient=9D and these are the things which should be thought about with the coming decades in mind. =46rom my limited experience, some items that fall into this category would be turnbuckles everywhere, a step, a comfy seat, a good fuel gauge, good brakes, a harness that is easy to adjust when sitting in that tiny cockpit with winter clothes on, a well-designed cowling that=99s easy to get off, with lots of access panels etc.> > That all being said, the VAST majority of builders use turnbuckles back there and I would if I were building again.> > $.02> > Douwe> > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D________________________________________________________________________________
Pietenpol-List: Re: tail turnbuckles
Posted: Thu Dec 05, 2013 10:15 pm
Mike,Thanks for your comment. I am using the -16S AN155 barrels that are 2.5" long,I miss-typed!I like you idea of using the clip typeTB. This could be a great way to go for thestabilizers , especially with the 1/16" cables and swigged ends. I will contactyou directly.Thanks again for your comments.Ray KrauseSent from my iPad> On Dec 5, 2013, at 5:33 AM, Michael Perez wrote:> > > "One could MAYBE avoid some drag, weight and airflow disruption by using justthe cable?"> > I like how you think Ray! One of the best places to keep weight to a minimumis, as you know, at the tail. So, it make sense to keep whatever you do putback there, light. I see you are looking at using 1/16" cable, considering theTB you mentioned. I believe Oscar uses this size cable, as am I. (I am yet tofly...) I am using TBs on the tail for the reasons Douwe has already mentioned.However, I have no experience with just using cable and twisting, so I can'tcomment on if they are as good, or better. If it saves weight, try it!> > You also mentioned using the -16S 4.5" long barrels. The -16S is "short" 2.25"long. If you can, use the short barrels for the weight and cost savings.> > The TB spares I have will all be the clip locking type and the cable ends arethe swage on type. (Page 130 in cat.) I am not sure I have any other assemblyparts, but I can check.> > If interested in having you cables swaged, we can chat off line.> > Please advise.> > > If God is your co-pilot...switch seats.> Michael Perez> Pietenpol HINT Videos> Karetaker Aero>
www.karetakeraero.com> > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: tail turnbuckles
Posted: Thu Dec 05, 2013 11:10 pm
I really like Douwe's observations on turnbuckles and other "optional" (?) stuff.In fact, I like turnbuckles just for their own beauty and design. The brassbarrels just look nice to the eye (mine, anyway), and a neatly safetied turnbucklecan be a work of art. I also second the comments about being able totweak the tension and adjustment of things. I've adjusted just about every turnbuckleon Scout at one time or another.Before I had my own Piet and I was only thinking about building one, I spent quitea bit of time researching hard-wire stabilizer bracing with wrapped ferrules.I really, really like the look of those but they require patience to makeproperly. There is evidence that the standing part of the wire fails in tensionby necking right at the ferrule, which means that the ferrule is not the weakpart. I don't think I've ever seen pictures of an Air Camper with hard-wirebraces made up with wrapped ferrules... just drawings and write-ups.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:
Pietenpol-List: Re: Helmets
Posted: Thu Dec 05, 2013 11:30 pm
Original Posted By: "bubbleboy"
Oscar, I have a write-up on wrapped and soldered ferrules for cable, even used some onthe wing drag wires, just to try it. They work OK, and look old. Not sure howthey last. Do they use the same method on hard wire? Nicopress is a lot easier!Thanks,Ray KrauseSent from my iPad> On Dec 5, 2013, at 9:10 PM, "taildrags" wrote:> > > I really like Douwe's observations on turnbuckles and other "optional" (?) stuff.In fact, I like turnbuckles just for their own beauty and design. The brassbarrels just look nice to the eye (mine, anyway), and a neatly safetied turnbucklecan be a work of art. I also second the comments about being able totweak the tension and adjustment of things. I've adjusted just about everyturnbuckle on Scout at one time or another.> > Before I had my own Piet and I was only thinking about building one, I spentquite a bit of time researching hard-wire stabilizer bracing with wrapped ferrules.I really, really like the look of those but they require patience to makeproperly. There is evidence that the standing part of the wire fails in tensionby necking right at the ferrule, which means that the ferrule is not theweak part. I don't think I've ever seen pictures of an Air Camper with hard-wirebraces made up with wrapped ferrules... just drawings and write-ups.> > --------> Oscar Zuniga> Medford, OR> Air Camper NX41CC "Scout"> A75 power> > > > > Read this topic online here:> >
http://forums.matronics.com/viewtopic.p ... 960#414960> > > > > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Helmets
Posted: Fri Dec 06, 2013 5:18 am
I purchased one of these!
http://www.gibson-barnes.com/prod-29404 ... --Tamworth, AustraliaBuilding a Corvair Powered Pietenpol Air Camperwww.scottyspietenpol.comTail and Ribs built...Building fuselage & undercarriage...Corvair engine atRoy's Garage waiting to be modified.Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 6 Dec 2013 03:47:55 -0800 (PST)
Posted: Fri Dec 06, 2013 9:12 am
Original Posted By:> taildrags(at)hotmail.com
My Piet had the hard wire with ferrule braces. > Subject: Pietenpol-List: Re: tail turnbuckles
Posted: Fri Dec 06, 2013 11:49 am
Original Posted By:> > taildrags(at)hotmail.com
Craig,Beautiful! What was the hard wire? What thickness, piano? Ferrules swigged, wrapped, soldered?Thanks,Ray KrauseSent from my iPad> On Dec 6, 2013, at 7:12 AM, Craig Aho wrote:> > My Piet had the hard wire with ferrule braces. > > > > Subject: Pietenpol-List: Re: tail turnbuckles
RE: Pietenpol-List: Re: tail turnbuckles
Posted: Fri Dec 06, 2013 5:57 pm
Original Posted By: raykrause(at)frontiernet.net
I don't remember the gauge of the wire I would have to look through my old notes to find out or mic one. I made a Jig per Gary Price's article in a way back issue of the BPA newsletter. it was fun to construct and had that old time look. No solder. They turned out great. Craig
Posted: Sat Dec 07, 2013 1:28 am
Solid wire ferrules. Notice that they aresquished oval.
http://www.theaerodrome.com/forum/repli ... tmlClifOld age and treachery will beat youth and enthusiasm every time. Someone I don't remember the gauge of the wire I would have to look through my old notes to find out or mic one. I made a Jig per Gary Price's article in a way back issue of the BPA newsletter. it was fun to construct and had that old time look. No solder. They turned out great. Craig Beautiful! What was the hard wire? What thickness, piano? Ferrules swigged, wrapped, soldered?________________________________________________________________________________Subject: Pietenpol-List: Re: Helmets
Posted: Fri Apr 28, 2017 9:38 pm
Original Posted By: "bender"
> To: pietenpol-list(at)matronics.com> > > I really like Douwe's observations on turnbuckles and other "optional" (?) stuff. In fact=2C I like turnbuckles just for their own beauty and design. The brass barrels just look nice to the eye (mine=2C anyway)=2C and a neatly safetied turnbuckle can be a work of art. I also second the comments about being able to tweak the tension and adjustment of things. I've adjusted just about every turnbuckle on Scout at one time or another.> > Before I had my own Piet and I was only thinking about building one=2C I spent quite a bit of time researching hard-wire stabilizer bracing with wrapped ferrules. I really=2C really like the look of those but they require patience to make properly. There is evidence that the standing part of the wire fails in tension by necking right at the ferrule=2C which means that the ferrule is not the weak part. I don't think I've ever seen pictures of an Air Camper with hard-wire braces made up with wrapped ferrules... just drawings and write-ups.> > --------> Oscar Zuniga> Medford=2C OR> Air Camper NX41CC "=3BScout"=3B> A75 power> > > > > Read this topic online here:> >
http://forums.matronics.com/viewtopic.p ... 960#414960> > > > > > > ============================================> > > 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: Pietenpol-List: Re: tail turnbuckles
Posted: Fri Apr 28, 2017 9:38 pm
Original Posted By: gcardinal(at)comcast.net
> > To: pietenpol-list(at)matronics.com> > >> > > > I really like Douwe's observations on turnbuckles and other "optional" (?) stuff. In fact, I like turnbuckles just for their own beauty and design. The brass barrels just look nice to the eye (mine, anyway), and a neatly safetied turnbuckle can be a work of art. I also second the comments about being able to tweak the tension and adjustment of things. I've adjusted just about every turnbuckle on Scout at one time or another.> > > > Before I had my own Piet and I was only thinking about building one, I spent quite a bit of time researching hard-wire stabilizer bracing with wrapped ferrules. I really, really like the look of those but they require patience to make properly. There is evidence that the standing part of the wire fails in tension by necking right at the ferrule, which means that the ferrule is not the weak part. I don't think I've ever seen pictures of an Air Camper with hard-wire braces made up with wrapped ferrules... just drawings and write-ups.> > > > --------> > Oscar Zuniga> > Medford, OR> > Air Camper NX41CC "Scout"> > A75 power> > > > > > > > > > Read this topic online here:> > > >
http://forums.matronics.com/viewtopic.p ... 960#414960> > > > > > > ===> > > > > > ________________________________________________________________________________Date: Fri, 6 Dec 2013 18:27:18 +0000 (UTC)
Original Posted By:> taildrags(at)hotmail.com
Craig=2CBeautiful! What was the hard wire? What thickness=2C piano? Ferrules swigged=2C wrapped=2C soldered?Thanks=2CRay KrauseSent from my iPadOn Dec 6=2C 2013=2C at 7:12 AM=2C Craig Aho wrote:=0A=0A=0AMy Piet had the hard wire with ferrule braces. > Subject: Pietenpol-List: Re: tail turnbuckles
