Pietenpol-List: prop finish
Posted: Sat Dec 14, 2013 5:29 pm
Original Posted By: "GNflyer"
aviken,I have attached a snapshot of the page in the AC 43.13_1b that discusses the variousproperties of wood. As you can see from the chart, poplar is not a directsubstitute for Spruce.Also, I am attaching a link to a downloadable copy of the AC 43.13. You can downloadthe entire reference, and it will answer many, if not most of your questions.That is not to discount the knowledge of many of these experienced builders(I am certainly NOT in that group), but it gives you a ready reference atyour finger tips as opposed to asking and then waiting for an answer.http://www.faa.gov/documentLibrary/medi ... ----Semper Fi,Terry HandAthens, GARead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/scre ... ___Subject: Pietenpol-List: prop finish
Re: Pietenpol-List: prop finish
Posted: Mon Dec 16, 2013 9:58 am
I'm awaiting the completion of my Cloudcars prop as well and would love to seea pic or two of yours finished Michael. Scott Sent from my iPhone> On Dec 16, 2013, at 7:56 AM, "Michael Perez" wrote:> > > That would be me. I received my propeller from Jay a couple months ago in therough. Jay included a note asking that I call him prior to doing anything onthe propeller, so I did. That was when the conversation came up about leavingthe machining scallops on it. We had a very nice, detailed conversation and fromthat, I decided to leave the prop. as received...VERY LITTLE sanding, not worthmentioning really, almost enough just to clean it up from being handled.(skin oils) I stained, painted and varnished the prop. and left all of the machiningmarks on it. The "fields"...the area Jay calls the glass coated tips...werenot sanded much either, just painted and varnished. I personally am nota big fan of smooth glossy finishes on some items, and leaving the propeller asis and staining, left a very nice, "aged" look with rich texture and color...justwhat I wanted.> > Theory is that the scallops act like a bird's feathers, dimples on a golf ball,or VGs, providing a better boundary layer on the airfoil. Jay told me thatothers leaving the scallops noted better performance.> > I figure that later, if needed, I can always remove the scallops... not so easyto add them after sanding them off.> > My propeller is now finished, balanced and on the plane. (not permanent as ofyet, working on tracking it now.) Very happy with how it looks, verdict stillout on how it performs, but I have no doubt it will be just fine.> > Feel free to contact me if you want to chat further.> > Merry Christmas.> > If God is your co-pilot...switch seats.> Michael Perez> Pietenpol HINT Videos> Karetaker Aero> www.karetakeraero.com> > > > ________________________________________________________________________________Date: Mon, 16 Dec 2013 12:04:44 -0600Subject: Re: Pietenpol-List: prop finish
Posted: Tue Dec 17, 2013 9:51 am
Posted: Tue Dec 17, 2013 10:12 am
Thanks Michael. Nice prop! Scott Knowlton Sent from my iPhone> On Dec 17, 2013, at 7:58 AM, "Michael Perez" wrote:> > Attached are two pictures showing the rough propeller in work. The first showsthe scalloped area on the prop. not yet stained. As I mentioned, I only didenough sanding to remove oils so that the stain would take. The second showsthe visible scallops with stain. You may also note the fiberglass "field" areabeing somewhat rough, (the bright area on the black paint)...minimal sandingon the fields as well.> > > If God is your co-pilot...switch seats.> Michael Perez> Pietenpol HINT Videos> Karetaker Aero> www.karetakeraero.com> > ________________________________________________________________________________Date: Tue, 17 Dec 2013 08:24:24 -0800 (PST)
Posted: Wed Dec 18, 2013 6:48 am
Pietenpol-List: Re: Suspended Propeller Balance
Posted: Wed Dec 18, 2013 8:33 am
great pictures! and again a very helpful explanation on your approach to balancing-thanks!Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 18 Dec 2013 07:05:02 -0800 (PST)
Pietenpol-List: Re: prop finish
Posted: Thu Dec 19, 2013 8:05 pm
Construction is progressing well. Five ribs built and turning out about 1.5 perday.I am reviewing the supplemental plans and laying out fuselage sides.On the extended fuselage, how does one determine where the "cross struts" (go betweenthe sides) are located?No dimensions for these on the supplemental plans that I can see. With the addedlength the dimensions from the original fuselage clearly won't work. I cansee where two inches were added in the first and third bays but this does nothelp locate the struts. I would think these locations are critical as they determinelanding gear, lift strut, cabane, etc attach points.What am I missing?ThanksGrant ZiebellSavannah, TNRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: prop finish
Posted: Fri Dec 20, 2013 8:27 am
Sorry Larry. MI don't have min either. Perhaps EAA has past issues for sale????Merry Christmas and I hope you find one.--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: prop finish
Posted: Fri Dec 20, 2013 9:19 am
thanks for all the great responses and pictures. makes it exciting to wait on thething to get here- not sure just what stain to use or even what wood theyare using o cut it from-should have asked earlier on. but when it gets here I'llhave a better idea of how to go with it now. RaymondRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: prop finish
thanks for all the great responses and pictures. makes it exciting to wait on thething to get here- not sure just what stain to use or even what wood theyare using o cut it from-should have asked earlier on. but when it gets here I'llhave a better idea of how to go with it now. RaymondRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 20 Dec 2013 07:32:15 -0800 (PST)
Posted: Fri Dec 20, 2013 9:35 pm
Original Posted By: "Braniff1966"
I actually asked him what he might have that was most affordable- he had 2 propscut sometime back stored way for Corvair engines. I wanted to stay with straightblades and get a few more inches pitch than my 66X29. he had a 32 or 33 anda 34 pitch. I think both as in the rough were about 72" long. he sold me oneworth the money and I will most likely cut it to around 68" long to start with.maybe even 70" if it looks like it will clean up well there and balance out.and can trim length if it proves to load it up too much a little at a time.since I fly from a pretty short and very un-forgiving strip I don't want to gettoo aggressive with pitch, but the one I have just gets me out really wellbut immediately have to throttle back quite a ways to avoid over speeding andI want to do little experimenting with a second one.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: prop finish
Posted: Fri Dec 20, 2013 10:31 pm
how do I get in touch with cloudcarsjim hydeRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Posted: Sat Dec 21, 2013 6:59 am
I don't understand the question or I would try to help my wings are almost done,fuse done tail covered and painted, center section done. wish I could help youjim hydeRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: prop finish
Posted: Sat Dec 21, 2013 7:09 am
their email- cloudcarsatverizon.net should do it.of course remove the at and use @Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: prop finish
Posted: Sat Dec 21, 2013 7:11 am
dadgummit- don't know why that posted like that-of course @ is the right atRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: prop finish
Posted: Sat Dec 21, 2013 7:19 am
Original Posted By: Chuck Campbell
[thanksRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
