Pietenpol-List: tail brace cables
Posted: Fri Feb 14, 2014 7:58 am
Original Posted By: Michael Weston
Hey Mike,A dull "thwang" is the basic advice I received when I asked. It's hard toquantify many things on a Piet and this seems to be one of them. I thinkgood common sense dictates here, so here's some basic common sense things toput into the mix.1. it's a wood structure so the cables shouldn't exert unnecessaryforce.2. the tail group is in the prop wash and really want a lot, so youdon't want the cables to allow for ANY movement.3. the tail alignment makes HUGE differences to your final trim, so thecables need to be easily adjusted during initial trim-inI think the main thing is to have them tight enough so nothing that move,and that they all be the same tension.I sat in on a lecture at Brodhead where the speaker talked a lot about tailalignment and the value of taking a lot of time in ensuring that everythingis square, including taking a measurement from the center of the fusesomewhere up front and ensuring the horizontal stab is exactly square asviewed from above. I worked hard to do this and she never needed a singletweak.Douwe________________________________________________________________________________
