Pietenpol-List: A65 Rose Bowl cut outs
Posted: Sun Feb 16, 2014 12:57 pm
I was a section leader when I flew in the Marine Corps but I know nothing aboutsection moduli. Let us know what you find out. I would be curious to know how aluminum tubing compareswith 1018 steel. FWIW, those screenshots came from onlinemetals.com--------Semper Fi,Terry HandAthens, GARead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: A65 Rose Bowl cut outs
Posted: Sun Feb 16, 2014 2:29 pm
Original Posted By: "g. doe"
Gentlemen Hi.I have just had made new aluminium front cowling 'rose bowl'.The lower half was manufactured with no cut outs or holes.Do I need to cut out the one or two holes I've observed on other aircraft suchas J3's or can I just leave as complete?The A65 install has so much air passing through the engine compartment it hardlyseems necessary.ThanksGerry________________________________________________________________________________Date: Sun, 16 Feb 2014 13:28:54 -0800 (PST)
Re: Pietenpol-List: A65 Rose Bowl cut outs
Posted: Sun Feb 16, 2014 4:02 pm
Post a picture Gerry. I am about to try one myself. GardinerSent from my iPadOn Feb 16, 2014, at 3:29 PM, Gerry Holland wrote:> > Gentlemen Hi.> I have just had made new aluminium front cowling 'rose bowl'.> The lower half was manufactured with no cut outs or holes.> Do I need to cut out the one or two holes I've observed on other aircraft suchas J3's or can I just leave as complete?> The A65 install has so much air passing through the engine compartment it hardlyseems necessary.> Thanks> Gerry> > > > ________________________________________________________________________________
Pietenpol-List: Re: A65 Rose Bowl cut outs
Posted: Wed Feb 19, 2014 11:18 am
Ben; that cutout does look kinda cute! I'll bet the skullcap spinner on the propadds at least 5 MPH to your top speed, too! ;o) By the way, is that the pitottube out there on the port side wing, near the strut attachment? I couldn'tsee anything else that might be it in the photo.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:
Posted: Wed Feb 19, 2014 12:49 pm
Ben,Is your "Rose Bowl" made of metal, or fiberglass? If fiberglass, did you make the"mold"? If metal, how did you do it?Thanks,Ray KrauseStruggling with my "Rose Bowl" for SkyScout.Sent from my iPad> On Feb 19, 2014, at 6:06 AM, Ben Charvet wrote:> > Why make it a horizontal cutout? I decided to give my Piet a smile!> > Ben>> On 2/16/2014 8:36 PM, taildrags wrote:>> >> Gerry;>> >> On most photos of J-3s that I've seen, there is a sort of horizontal slot justbelow the hole for the prop hub and then a round hole below that, and thenthe air filter. I have no idea what the horizontal slot is for but I believethe hole below it leads into the heat muff for carb heat since I believe it hasa mesh screen in the opening. Neither of those openings should have anythingto do with cooling the engine or oil sump. However, the J-3 does not have apressure cowl so there is cooling air entering through the eyebrows, sweepingdown over the cylinders, the out the bottom of the cowling after going aroundthe oil sump and carb.>> >> I think you can dispense with any additional cutouts. Test fly it and watchthe oil and cylinder head temps and then decide if you need any additional openings.It's easier to cut new ones than to patch ones that you don't need.>> >> -------->> Oscar Zuniga>> Medford, OR>> Air Camper NX41CC "Scout">> A75 power>> >> >> >> >> Read this topic online here:>> >>
http://forums.matronics.com/viewtopic.p ... 834#418834> > > -- > Ben Charvet, PharmD> Staff Pharmacist> Parrish Medical center> > ________________________________________________________________________________Subject: Pietenpol-List: Re: A65 Rose Bowl cut outs
Posted: Wed Feb 19, 2014 12:59 pm
I think Gerry calls his a "Rose Bowl" because it's on a Rose Parrakeet. I guessours could be called a "Pieten Bowl" ;o)--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: A65 Rose Bowl cut outs
