Pietenpol-List: Eyebrow cowlings
Posted: Sun Feb 16, 2014 7:36 pm
Gerry;On most photos of J-3s that I've seen, there is a sort of horizontal slot justbelow the hole for the prop hub and then a round hole below that, and then theair filter. I have no idea what the horizontal slot is for but I believe thehole below it leads into the heat muff for carb heat since I believe it has amesh screen in the opening. Neither of those openings should have anything todo with cooling the engine or oil sump. However, the J-3 does not have a pressurecowl so there is cooling air entering through the eyebrows, sweeping downover the cylinders, the out the bottom of the cowling after going around theoil sump and carb.I think you can dispense with any additional cutouts. Test fly it and watch theoil and cylinder head temps and then decide if you need any additional openings.It's easier to cut new ones than to patch ones that you don't need.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sun, 16 Feb 2014 19:44:38 -0600Subject: Pietenpol-List: Eyebrow cowlings
