Pietenpol-List: Vasek's production of Historic Propellers
Posted: Sun Mar 02, 2014 3:29 pm
Original Posted By: "Vasek"
[bmw makes sorry bikes.. read the maint reports..Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Vasek's production of Historic Propellers
Re: Pietenpol-List: Vasek's production of Historic Propellers
Posted: Sun Mar 02, 2014 4:48 pm
Vasek,Given that those engines are not common in Europe (I would love to visit the Czech Republic some day, most people do not realize your country's contributions to European & western culture), I might suggest that you seek out a water-cooled 4-cylinder engine that has a power curve similar to the Ford Model A, either inherently, or by installing a modified cam. There are many of these available - modern Ford engines like the Fiesta and Pinto, possibly the 4-cylinder engine that powered Toyota Trucks in the late 1970's - early 1980's period, engines from any number of European cars (Fiat, perhaps?). You would convert these very similarly to converting the Model A, so you would have a a path to follow. I was considering doing this with my old Toyota truck engine until I lucked onto a free Corvair engine.Kip GardnerOn Mar 2, 2014, at 5:00 PM, Vasek wrote:>> Fords and Corvairs and not very common here in Europe, so I am > searching for alternatives :)>> Thanks for your comments!>> --------> My production of WW1 propellers, trophies and constructions:> >>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... ______Date: Sun, 2 Mar 2014 20:24:55 -0600Subject: Re: Pietenpol-List: Vasek's production of Historic Propellers
Posted: Sun Mar 02, 2014 8:49 pm
Posted: Mon Mar 03, 2014 7:09 am
Original Posted By: Vasek
Wow Vasek those props are magnificent! I really admire you for being able to carve those beauties, and to be able to make it into a business for yourself is a huge bonus. Good for you and your friends. Wishing you all the best!Dan HelsperPuryear, TN-----Original Message-----
Pietenpol-List: Re: Vasek's production of Historic Propellers
Posted: Mon Mar 03, 2014 11:05 am
John; there are ways to do it in the air, using the GPS, but to me it's easierto do it on the ground with a compass rose than in the air.Steve; well, duh... notice that I mentioned the brass screwdriver in my post? ;o) Also, you don't describe the procedure quite right. You only take out halfthe difference when you turn to the S and W headings.Jack; believe me, I have noticed the very effect that you mention, with the compassslowly moving away from heading if the stick is moved closer or farther fromthe compass. Duly noted, sir!--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Vasek's production of Historic Propellers
Posted: Mon Mar 03, 2014 11:45 am
Thank you for the nice words, I very appreciate it. I can post photos of some ofour interesting projects if you wish. We will have a four-blade propeller fromR.E.8 soon in the "old style" and a big beautiful Chauviere prop from D.H.1.> Perhaps your Piet should have some styling to remind us of a pre WWII Avia orLetov. It definitely could have! Do you have any suggestions?> Are there any old Waltor Minor engines floating around? they are somewhat comparableto at Contental O200 while about 30 pounds heavier. Yes, I think that I could find some, but I have a feedback from a guy who had GN-1that the Walter was too weak. He replaced it with Subaru with a reductiondrive.> There is no reason that you could not break into the Prop or construction business.The question is, would people be interested in these carved propellers? I mean,airworthy? Such a prop would be at least three times more expensive than it isnow.--------My production of WW1 propellers, trophies and constructions:Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Piet parts for sale
Posted: Sun Mar 09, 2014 10:05 pm
Original Posted By: Brian Durham
Subject: Re: Pietenpol-List: Piet parts for sale
Re: Pietenpol-List: Re: Vasek's production of Historic Propellers
Posted: Fri Apr 28, 2017 9:38 pm
>>>> > To: pietenpol-list(at)matronics.com>> >>> WilliamTCA(at)aol.com>>> >>> > Brian,>> > You are correct on the limits of compression increase on flatheads. The>> point I was trying to make is that Kenny's HP per cubic inch at 6.5:1>> should be better than the Ford HP per cubic inch at 4.25 to 5.25:l. The>> limits for increasing on the Jeep may be higher still, as it has a wildly>> under square bore and stroke ratio.>> >>> > Manifolds on flatheads are on the same side and short, good for compact>> turbo installation. The exhaust pressure is less than you may suspect, the>> energy of the exhaust gasses is primarily heat. In an enclosed compartment>> always a concern, especially with a lot of joints, but I was kind of>> picturing it out in the slipstream. I am pretty sure someone brought a>> turbocharged Piet to Brodhead in the last decade, but I can't remember who>> it was.>> >>> > Part of the reason why I am optimistic about Kenny's project is>> thinking about A-37 and A-40 Continentals. They are flatheads also, they>> have less cubic inches. They are maybe 80 pounds lighter, but they did fly>> a lot of stuff like J-3s on floats with light people.-ww>>>> >>> >>> >>> >>> > Read this topic online here:>> >>> > http://forums.matronics.com/viewtopic.p ... 056#420056>> >>> >>> >>> >>> >>> > =============>> >>> >>> >>>>> *>>>>>> *>>>>>________________________________________________________________________________Date: Sun, 9 Mar 2014 21:49:24 -0500Subject: Re: Pietenpol-List: Re: Vasek's production of Historic Propellers
