Pietenpol-List: corvair engine serial numbers
Posted: Fri Mar 14, 2014 1:47 pm
Original Posted By: "Bill R"
Hi Piet builders,Got a generic wooden plane question for y'all. I have an airframe that steel nailswere used to attach a bulkhead to the fuselage framing. The glue joints lookgood; but, I have discoloration everywhere he put the steel nails. (Note hedid end up going to brass, but about half the structure he used steel). Is thissomething some of you have seen in the past? If so, what are your thoughts?Remove and replace, or seal and monitor?Thanks,Brian Durham--------Brian DurhamRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: corvair engine serial numbers
Posted: Fri Mar 14, 2014 2:07 pm
Guys I found three motors for sale, the numbers on the block are as follows:To702ZHT0205YRT0 605RBCan anyone tell me if any of these motors will work for a WW conversion?ThanksBillRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 14 Mar 2014 14:25:25 -0500 (GMT-05:00)
Pietenpol-List: Re: corvair engine serial numbers
Posted: Fri Mar 14, 2014 2:56 pm
ScottClosest I came to a ride in your plane was this, http://www.westcoastpiet.com/images/WCP ... G_0512.JPG I realized Sunday morning as you were getting ready to leave that I forgot toget a ride. Sure sucked to be left standing on the ground as everyone flies away. I guessI need to build faster.--------ChrisSacramento, CAWestCoastPiet.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: corvair engine serial numbers
Posted: Fri Mar 14, 2014 3:29 pm
ZH = '64 95HP powerglideYR = '60-'63 turboRB = '65-'68 manual, 140HPThere are more suitable candidates than any of these.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: "Hooking them in"
Posted: Fri Mar 14, 2014 5:08 pm
Nice! Love the wood struts!Gary BootheNX308MB-----Original Message-----
