Re: Pietenpol-List: Re: CG vs Wheels Location..emergency situation
Posted: Sat Mar 22, 2014 8:32 am
This is not a simple problem and it is hard to give correct advice and it is the classic example that everything is compromise.The following are variables that effect the gear position. If you are wonder "what the heck: then I will give an example of why some of these are important.VARIABLESthe empty c.g.the loaded c.g.the expected c.g rangethe fuel placementthe maximum weight of the pilot=2C the minimum weight of the pilotthe assumed wing position=2C the final wing positionthe strength of the brakesthe diameter of the wheelsthe total height of the c.g above the ground. WHAT THE VARIABLES EFFECTThe weight on the tail when emptywhether the tail will stay down while empty in a windthe strength of the tail wheel spring and structurethe ability to stop with brakesthe ability to hold the aircraft on run upthe overturn tendency with brakesthe directional stability (ground looping tendency)the tendency for the tail to drop hard on landing (if not three pointed)the tendency to porpoisethe ground handlingwhat the government says about c.g.Here is an example - I will use my example so not to offend anyone.My aircraft has wooden gear=2C motorcycle wheels with brakes =2C and perpendicular cabanes. It is an improved fuselage from the 1933 plans and the stock 1931 wooden gear. The fuel is behind the firewall.I am happy with arrangement but it has limitations and it could easily criticized as wrong=2C but being wrong has some advantages. As built my airplane has the following advantages-the load on the tail is very light and the structure is light helping the aft c.g. tendency - the gear is back in comparison to many giving improved handling and stability on landingthis means the tail is not forcefully driven down if you land hard .-the tail comes up very easily on the take off roll. -it has had thousands of landings over 27 years and it has never been damaged in a landing incident. This aircraft is not squirrelly at allthe large wheels reduce rolling resistance=2C and reduces takeoff distance.- large wheels move the contact point of the wheels in the three point attitude to the rear making it more directional stable.-the fuel in the fuselage reduces the weight transfer back to the tail as the tail drops in comparison to fuel in the wing.My gear position has the following disadvantages-If I had stronger brakes it would be a danger to flip over - I am very happy with my brakes however - they won't hold on a runup buy I don't think that would be a good idea anyway. -my tail is so light when empty that if you lift the tail past horizontal the airplane will fall on its nose - never has=2C but don't lose hold-I operate at and around the aft cg limit. If I were to put weight on the nose to make the recommended c.g. limits for aircraft built in Canada=2C I could not get out of the aircraft as it would fall on its nose. Where I operate the c.g. is as recommended for a Pietenpol and there is not a problem. It may improve the climb performance.-As I age and get heavier the c.g. is getting more aft and adding weight to the nose would make the gear position worse in the rear direction - it is not really a problem and I can have full fuel and a metal prop instead of a wood one. I really added this to show how the pilot max weight effects the setup. -if a very light pilot used my brakes very hard the tail would come up far easierRemember too that many Piets end up with aft cgs and they move the wing back once built. This moves the wheels forward. Best laid plans quickly change. One of my favourite saying is - you can be good or you can be lucky but it is always best to be lucky. ________________________________________________________________________________Subject: Re: Pietenpol-List: Re: CG vs Wheels Location..emergency situation
