Pietenpol-List: Joseph Jameson's Corvair engine runs
Posted: Tue Apr 01, 2014 7:42 am
Hello good Piet-ple,Things are progressing well on my 1931 Pietenpol, yet this time of year thoughtsoften turn to "What project next"...?!?!I've been thinking that perhaps the Pietenpol needs updating a bit while stillkeeping with the designer's original intent. What better way to do that thanby creating a sheet metal version of the design - the Sheet-en-polI've run some numbers and it looks like the RV-8 wing and empennage would workwell. These parts are readily available as component kits from Vans. This wouldallow me to concentrate most of my design work on the fuselage and paint scheme.The canopy from the RV-8 should fit nicely around the tandem seat arrangementwhich would make the plane useful for a greater portion of the year - especiallyconsidering all the rain we get here in Seattle. The canopy feature mighteven work well in places like Minnesota where the original was designed orOhio where so many Pietenpols get built for some strange reason. (Maybe causeit is the birthplace of the Wright Brothers or something!)I ran some flow analysis (see image) and it looks like with all the changes thedesign might actually reduce the drag enough to require the installation of anairspeed indicator. Not wanting to bite off too much by designing both an experimental airframe ANDan engine (no one would ever want to do THAT) I would use only a certified automotiveconversion.Glad for these early springtime April days to be able to let the mind wander abitJake--------Jake Schultz - curator,Newport Way Air Museum (OK, it's just my home)Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/piet ... ___Subject: Pietenpol-List: Joseph Jameson's Corvair engine runs
