Pietenpol-List: gap seals on the tailfeathers
Posted: Thu May 08, 2014 8:36 am
I have found that the elevator and rudder response in the Pietnpol is superb and requires no gap sealing unless you're thinkingyou might get a slight reduction in drag but to me it isn't worth it. There is so much drag back there to begin (tail brace wires, tailwheeland tail spring assemblies) with that getting a little less drag out of the gaps will create more headaches than it is worth when they startto peel and look ratty over the years.Gap seals back there also make it more difficult to do satisfactory preflight inspections of the tail hinges, pivoting hardware, and cotters/securing nuts.If you want drag reduction, build and RV-something.Mike C.Ohio________________________________________________________________________________
