Pietenpol-List: Corvair Engine Mounts
Posted: Tue May 27, 2014 11:25 pm
Original Posted By: "john francis"
Did anyone happen to visit the wooden float tent/forum/workshop at SNF where DickNavratil and Dave Aldrich were building the floats? I never heard a reportabout how far they got, and didn't see any pictures either.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Corvair Engine Mounts
Pietenpol-List: Re: wooden floats at SNF
Posted: Wed May 28, 2014 12:16 pm
I received a drawing from Mark Chouinard of the engine mount fittings for a Corvairengine. Except for the cost of the additional 4130 steel, it is just aseconomical for me to have 4 sets water cut as it is one. If anyone is interested,I will sell them at cost ($50.00) plus freight.Thanks,John--------John FrancisRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: wooden floats at SNF
Pietenpol-List: Re: Corvair Engine Mounts
Posted: Wed May 28, 2014 1:18 pm
Original Posted By: "K5YAC"
Bring the floats to Frazeur Lake. Then we could use their water runway. Now thatwould be fun.--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Corvair Engine Mounts
Posted: Wed May 28, 2014 2:10 pm
Original Posted By: Charles Burkholder
By the way, these aren't just Corvair mounts... they are the mount fittings shownin the plans. If I recall correctly, they are not specific to any engine configuration.In case anyone was wondering, yes I did get rid of the set I had at Brodhead lastsummer. Won't say for how much... but you are welcome EchoBravo. [Wink]--------Mark ChouinardAll framed up... working on rigging.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 28 May 2014 17:23:46 -0500
Pietenpol-List: Re: Elevator & rudder hinges from square tubing sections
Posted: Wed May 28, 2014 5:00 pm
Getting ready to fabricate elevator and rudder hinges. Rather than the multi pieceweld up on the plans I was going to try sections of telescoping 1in and .75in .065 wall square 4130 tubing. Easier to fabricate and the multiple .065walls would give more bearing area than the .090 welded up hinges. Also wouldrequire no welding(a plus in my book!) Plan tonuse AN 3 bolts with castle nutsas the hinge pins.Wondering if anyone has already tried this. Thoughts from the group?ThanksGrant ZiebellSavannah, TNRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Elevator & rudder hinges from square tubing sections
Posted: Wed May 28, 2014 6:51 pm
Grant,That sounds terribly heavy and unproven. You should reconsider since there is absolutelyno reasons to beaf up the structure. There has never been a known structuralfailure on a plans built Piet. You also need to keep a very close eyeon any weight you add to the back and of these birds. Please reconsider.Very respectfully,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Elevator & rudder hinges from square tubing sections
Posted: Wed May 28, 2014 7:00 pm
Original Posted By: larharris2 Harris
Grant,Pardon my previous post. I must be tired. Somehow I thought you included the controlhorns in the question. For hinges it may work. My apologies,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Posted: Wed May 28, 2014 8:02 pm
Original Posted By: "aviken"
I tried this method. The hinges work out OK=2C but I am not happy with my precision in locating the holes in opposite 'ears.' I am using clevis pins=2C secured with cotter pins=2C as the hinge shaft. Each hinge half gets a single 3/16 AN bolt as attachment. This requires a slight inset cut in the wood to prevent rotation. I've already mounted the elevator sets=2C but not the rudder set. I get full travel on the control surfaces=2C but I am not happy with the alignment. I'm looking for a set of the 'original' Vi Kapler hinges.Lorenzo 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________________________________________________________________________________Subject: Pietenpol-List: Re: Corvair Engine Mounts
Posted: Wed May 28, 2014 9:25 pm
Original Posted By: "Dick N"
Hi I am interested in set of mount fittings.... You can e-mail me at/ aviken(at)windstream.netRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: wooden floats at SNF
Posted: Wed May 28, 2014 10:34 pm
Hi OscarAt SNF we got one set basically framed in, we didnt have time to do the second set. I have the first set at home and I havent had time to do anything more since I got them here. I first have to determine the CG to attach the support brackets. When that is done I can cover the floats.Dick N.----- Original Message -----
Pietenpol-List: Re: Elevator & rudder hinges from square tubing sections
Posted: Wed May 28, 2014 10:38 pm
Dick;There should have been some seaplane people at SnF since they have a splash-inlocation nearby at Lake Agnes or something. I'm sure seaplane guys would knowjust how to go about optimizing the mounting point placement. It will be interestingto follow your progress!--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Elevator & rudder hinges from square tubing sections
Pietenpol-List: Re: wooden floats at SNF
Posted: Wed May 28, 2014 10:44 pm
I would suggest that you dig into your hardware bin for the length of AN3 boltthat you plan to use on the hinges, plus a washer and locknut, and compare theweight of one of those sets of hardware to the standard AN393 clevis pin plusa thin washer and cotter pin. Multiply the difference in weight by 9 sets oftail surface hinges and see what that will add to the weight of your tail.After wrestling with clevis pins and cotter pins on the tail surfaces (especiallywith tight hinge gaps) made me think about using bolts and nuts too, but it'snot real easy to get wrenches in there to turn them... and impossible to geta socket or ratcheting box-end on them.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: wooden floats at SNF
