Pietenpol-List: Pietenpol motor mount drop
Posted: Mon Jun 16, 2014 1:47 pm
Original Posted By: "Lithuanian"
Wouldn't those expansion calculations be for if the piston was a solid piece? Nearly 7 thou expansion at a rather low temp seems excessive. Also, pistons don't generally expand evenly, which is why modern pistons are camground.Lastly, I did just find a 1931 reference to tolerances used in the manufactureof the Ford A, and it mentions .002 MAX.Now, I do know it's common to simply overbore to address issues like these, butif .002 is the manufacturers recommendation, and most chevy guys seem to indicateabout.004 is alright (for the MUCH higher horsepower and rpm ranges of v8small blocks) for street engines... something just doesn't add up. I think factoryspecs are about .003 max out the door. The .007 and up clearances seemto be used mostly by guys really hot rodding the engine, not producing 50 hp...Besides ring end gap, have you checked the fit of each piston in several locationsin the cylinder? Perhaps your block is tapered... Checked in several clockcodes to try and find out of round? Perhaps a six pack of beer and a googlesearch for a car club in your area to find someone with a bore gage you canplay around with to help determine exactly what is going on. Also a good micrometerto double check the pistons.Also, are you using forge or cast pistons? Cast need more clearance.I just hate over boring (honing) without really knowing, because that will shortenthe life of the engine.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Pietenpol motor mount drop
