Pietenpol-List: BFR
Posted: Sun Jul 06, 2014 9:40 am
Thanks, William. As always, I appreciate your insight on risk management in homebuilding.Thoughtful builders will read carefully.--------Kevin "Axel" PurteeRebuilding NX899KPAustin/San Marcos, TXRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Sun, 6 Jul 2014 09:59:39 -0500Subject: Pietenpol-List: BFR
Pietenpol-List: Re: BFR
Posted: Thu Oct 30, 2014 3:40 pm
I am finishing up my rudder and stab. I like the simple Ray Allen Trim Servo. Installit in the elevator just like you would a RC Servo and push rod. For powerif I do not have a starter battery, I will power trim system with a lipo batteryalong with my hand-held and GPS. (On the same subject of controls) I have looked at the geometry of the elevatorsystem and it does not work out. Do the control cables sag as you change stickposition. If you move the control stick forward 15degs. and back 15 degs., thecable push and pull is not even. This is because the cable on the back stickconnection comes under the 2" pulley, and the front cable goes over the topof the pulley. The cables from the bell crank to the elevator do not work out.they hit the front of the horizontal stabilizer and sag. What can be done tofix this? Is it something to worry about. The bell crank on the original plansunder controls calls for the bearing to be 9" off the bottom. On the extendedfuse update 7-1/8". In another area it calls out 7". The lower it is the moreit rubs.--------ScottRead this topic online here:
http://forums.matronics.com//files/cabl ... ___Subject: Pietenpol-List: Re: BFR
Posted: Thu Oct 30, 2014 3:45 pm
I assume he jumped. Where there's smoke, there's fire? Were you able to get hissignature in your log book before he croaked?
--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:
RE: Pietenpol-List: BFR
Posted: Thu Oct 30, 2014 3:54 pm
Too funny Gary!!! You alarmed him a bit did you? I'll bet once he knew it was intentional he liked it.Smoke on!!!Mike C.OhioPS-well......did he pass you?????
Pietenpol-List: BFR
Posted: Thu Oct 30, 2014 5:37 pm
RE: Pietenpol-List: Re: BFR
Posted: Thu Oct 30, 2014 5:57 pm
He was laughing about it by the time we got down...:-)Gary BootheNX308MB-----Original Message-----
