Pietenpol-List: ordering wood
Posted: Thu Jul 17, 2014 12:43 pm
Original Posted By: "Pocono John"
Jon,Here is the main college page with links to almost all questions:http://flycorvair.net/2014/01/31/corvai ... ------Here are examples of what builders learn:http://flycorvair.net/2012/11/06/basic- ... ----Things you need to run an engine at a college part 1:http://flycorvair.net/2012/10/04/runnin ... ------Part 2:http://flycorvair.net/2013/01/23/runnin ... ------Here are photo links to all colleges, if you read the captions on colleges like#19, 21, 22, 24, 28, 29 you can get a good idea of the prep work that will benefityou.http://flycorvair.net/2013/12/29/corvai ... ------John Franklin Piet engine running at #22 (Kevin and Shelley's place in TX)http://flycorvair.net/2012/03/20/frankl ... -------You can look at CC#21 and See Bob Dewenter's Piet engine running. In all the links are plenty of photos of guys building Piet engines, many of which are flying today. The Bell's Piet engine is in the #7 photos, Randy Bush's 500 flight hour engine is getting it's test run in the #19 photos. You can even see Doc Moshers pictures at Corvair College #1. If you are a piet builder, Consider #31 also, as this will be the 5th year we will be with PF Beck and Crew in Barnwell in November. This is the end of the year event where we award the Cherry Grove Trophy: http://flycorvair.net/2013/01/18/the-ch ... ------Sign up information:http://flycorvair.net/2014/06/19/corvai ... -open/Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: ordering wood
