Pietenpol-List: side note about smoke and smoke oil for Pietenpols
Posted: Fri Aug 01, 2014 3:32 pm
Gary-smoke is just a blast to have. With your electrical system you could probably use a salvage yard or new replacement windshieldwasher pump/reservoir setup. I don't know if the washer pumps have the kind of pressure you need but I don't see why it wouldn'twork as long as it could overcome the backpressure in the exhaust stack. You only need to inject into one exhaust stack too. As long asyou inject in that first 1-2" the oil with smoke really well.I believe Chuck Gantzer used a windshield washer pump for his baby oil smoke system and it worked well but the baby oil didn't have as whitea look as the mineral oil.I use the regular air show smoke oil so it does well but isn't cheap but thankfully some distributors sell it in 5 gallon buckets. Not sure what the tradename for the stuff is now since I haven't purchased any in a while but it used to be Texaco Canopus Oil #13, before that it was Corvis oil.Kyle Franklin posted this on his web page about the various smoke oils he asks for when making an air show appearance.[cid:image001.png(at)01CFADA6.1E994010]________________________________________________________________________________
