Pietenpol-List: resend-- N8031 on takeoff with smoke
Posted: Tue Aug 05, 2014 6:52 am
Jeff! Your video was great, especially in light of the fact that your son didn'tknow you installed the smoke system. You can tell hereally enjoyed it once he realized the engine wasn't having a problem. Very coolstuff. Your home airport looks like the perfect placeto keep a Pietenpol!Mike C.Thanks Mike for the smoker system idea!Here a video of my son and myself and he did not know I installed the smoker system!ThanksJeffN8031https://
www.youtube.com/watch?v=OqNkgQo2e5Q&sns ... __________
Re: Pietenpol-List: how far down the stack to inject smoke oil
Posted: Tue Aug 05, 2014 7:31 am
Original Posted By: Jack
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________________________________________________________________________________Subject: Re: Pietenpol-List: how far down the stack to inject smoke oil
Posted: Tue Aug 05, 2014 7:48 am
Thanks Uncle Mike!Sent from my iPadJack Textor> On Aug 5, 2014, at 7:31 AM, "Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC]" wrote:> > Jack=94I welded my fitting to the exhaust pipe Jack but I suppose brazing would work well also. The poly spray bottle has a check valve of some sort> built in so when you=99re not flowing oil the exhaust gas backpressure isn=99t a factor as far as I can tell. Good question though. Although I don=99t have one> a simple in-line liquid one way check valve might not be a bad idea. > > The fitting is simply welded to the exhaust stack and doesn=99t protrude at all into the stack. The only holes that are drilled are two No. 60 holes spaced> about 1/8=9D apart from each other in the wall of the exhaust pipe. > > Actually I welded my fitting onto the exhaust stack and then drilled the No. 60 drill holes in the center of the =C2=BC=9D opening of the fitting. > > Mike C.> > Below I used a piece of conduit to illustrate how the two holes look in the exhaust pipe and the various fittings one might use to weld/braze onto> the exhaust pipe wall. > > > > ________________________________________________________________________________
