Pietenpol-List: Jeep engine
Posted: Tue Sep 02, 2014 12:54 pm
Original Posted By: "aviken"
Jim,I will have about 6 pieces, 6" long, what do you need. You may have it. Let me know.RaySent from my iPad> On Sep 2, 2014, at 10:12 AM, Jim Boyer wrote:> > Hi Ray, I need a piece of 1x1 yet myself; my struts are the large size from Carlsons.> Thanks,> Jim> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> ________________________________________________________________________________Subject: Pietenpol-List: Jeep engine
Posted: Tue Sep 02, 2014 1:06 pm
Hello again... I have some information that I have developed recently... I wasattempting to match the Jeep 134 L head Go Devil engine, Of WW2 fame to use inthe place of a Model A on my pietenpol project. I progressed to the point ofinstalling a Slick mag and new intake and exhaust as well as installing atachometer drive mount. After testing with a Tillotson Model A Carb which itonly managed 1600 rpm, I tried it with a larger Bendix carb and got it up to1800. This is with a 72 inch Seninich prop from a Champ.... I had hoped forat least 2000 rpm. I have decided that the jeep engine is probably too smallfor the task, And I have moved on to other options. If anyone would liketo continue this test or have any questions please give me a call at 870-926-7165.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/engi ... ______Date: Tue, 2 Sep 2014 11:06:31 -0700
Re: Pietenpol-List: Jeep engine
Posted: Tue Sep 02, 2014 2:22 pm
Thanks, Mike! I aspire to smoke like any one of those guys!GarySent from my iPhone> On Sep 2, 2014, at 11:59 AM, "Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC]" wrote:> > Great work Gary Boothe in getting your smoke system working. Your video are fantastic and thanks for taking us along for the ride. Here are a few> others who are also having fun vaporizing the daylights out of various oils. A shiney Luscombe and a few others at the Antique Airplane Association Fly In> at Ottumwa, Iowa this past weekend. > > Mike C.> Ohio> > > > > > > > > > > ________________________________________________________________________________Date: Tue, 2 Sep 2014 14:38:18 -0500Subject: Re: Pietenpol-List: Jeep engine
Posted: Tue Sep 02, 2014 2:38 pm
Pietenpol-List: Re: Jeep engine
Posted: Tue Sep 02, 2014 2:39 pm
Ken,Don't throw in the towel just yet! A few more easy tests might reveal some betterresults....1) Borrow a manifold pressure gage from someone or buy a cheap one. tap it intoyour intake and re-run the engine at wide open throttle and note the reading.If it is not within 1" of ambient pressure, you need a bigger carb.2) How far advanced did you try the timing? 3) A champ prop is a good prop for a 65hp engine with a 2375 redline, but I suspectthat you are leaving a lot of ponies in the barn by shooting for too lowan rpm. All of my loaner Corvair props have the same SAE 1 bolt pattern, but theyhave opposite rotation blades. If need be, I could scrounge up some in yourrotation. I suspect that a 66" two blade prop set for 2,500 static rpm wouldprovide a very different hp and thrust picture for your engine. As an enginewith a pressurized oil system and insert bearings it will not be harmed by thisrpm. I am guessing 1800 isn't even the torque peak for the engine. The rightprop to allow your engine to speed up some is in order.4) My friend Bob Lester, who switched from a 65 Lycoming to a Corvair on his Pietmay still have the original prop, and they have somewhat less pitch and areathan a Continental prop, as they were certified at a higher rpm, I will findout if you can perhaps test this, if we can't put option #3 together.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Jeep engine
