Pietenpol-List: Fuselage Side
Posted: Tue Jul 07, 2015 10:22 am
Should I glue the 1/8" plywood to the outside forward section of the fuselage likeshown on the Pietenpol home site before assembling the 2 sides together? prosand cons?--------Harv, 485PBRead this topic online here:
RE: Pietenpol-List: Fuselage Side
Posted: Tue Jul 07, 2015 10:52 am
I did. Many don't but I didn't see any problem with gluing it on, and it'smuch stronger.Jack PhillipsNX899JPSmith Mountain Lake, Virginia-----Original Message-----
Re: Pietenpol-List: Re: Fuselage Side
Posted: Tue Jul 07, 2015 12:13 pm
The disadvantage to gluing the side sheeting on early in the game is that youraccess into the fuselage will be limited. This will become more of an issue whenyou start trying to fit and install the seats and control system, since youwill only be able to access the space through the top (assuming you have installedthe floor as well.Many builders opt to postpone the installation of the side sheeting as long aspossible, in order to retain as much access as possible during the constructionprocess.Bill C.Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 7 Jul 2015 19:49:33 -0400Subject: Re: Pietenpol-List: Re: Fuselage Side
