Pietenpol-List: Any Piets living in Southern Ontario?
Posted: Mon Aug 24, 2015 11:30 am
Original Posted By: "BritishJim"
Hi Jeff,I bought the home built Grove 6.00x6 magnesium wheel and disc brake kit from aircraftspruce and bought the tires and tubes direct from Desser Tire. I thinkaired up they were inch taller than on the plans 20" vs 19" if I remember correctly.I am working on building my landing gear so not sure on the stance whenon yet but in my opinion they are just right for the look I want. Not too bigand not too small. All my measurements are to the plans with steel gear and ModelA engine.RobRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/imag ... ___Subject: Pietenpol-List: Any Piets living in Southern Ontario?
Re: Pietenpol-List: Any Piets living in Southern Ontario?
Posted: Mon Aug 24, 2015 1:02 pm
Original Posted By: Scott Knowlton
Greetings all!I'm in London, Ontario for the next couple of weeks and wondering if anyone knowsof any Piets in the area, or has contact information for owners?My full-time base is Nova Scotia where there is virtually no intelligent life,let alone a Piet owner. I figured, now that I'm in the civilized world for a fewweeks, it might be good to try and hunt one down.Any help would be greatly appreciated. Jim.--------Your nose is high; you're in the sky. The other way around; you'll hit the ground....Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Any Piets living in Southern Ontario?
RE: Pietenpol-List: Any Piets living in Southern Ontario?
Posted: Mon Aug 24, 2015 1:12 pm
There are a couple in the Midland area but that is a longer driveRobert Gow,President and DAO Manager.Avionics Design Services Ltd.Phn 705-527-6095Cell 416-434-3393Fax 705-527-6028www.avionicsdesign.ca -----Original Message-----
Re: Pietenpol-List: Re: Any Piets living in Southern Ontario?
Posted: Mon Aug 24, 2015 1:23 pm
Robert & Scott....thank you for such prompt replies!Scott - are you @hotmail.com or @hotmail.ca? It is cut off on your username andI don't want to email some random Joe who will think I'm obsessed with an actualman called "Pete".Thanks,Jim.--------Your nose is high; you're in the sky. The other way around; you'll hit the ground....Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Re: Any Piets living in Southern Ontario?
