Pietenpol-List: Light at the end of the tunnel...
Posted: Fri Oct 23, 2015 2:11 am
Original Posted By: Charles Burkholder
Subject: Re: Pietenpol-List: POH SpeedsCan you kindly give the address (link) of the pietenpol pilot operatingmanual? I will need one and I also have to translate it to turkish.RegardsSemih=8B2015-10-23 6:52 GMT+03:00 Steven Dortch :> Fellow Pieters, What operating speeds do y'all use?>> I have just edited a Pietenpol Pilot Operating handbook for my Piet. I> found it on the Matronics list and it looks very complete.>> My plane has the Pietenpol wing and has a 65 HP Continental.>> Where a cub has 60MPH as the standard speed to do most everything: climb,> final, engine out, longest range. This manual uses the following:>> Best angle of climb, 55MPH>> Best engine out glide 55 MPH>>> Normal Climb Out 65 mph>> Short Field Takeoff 55> mph>>> Enroute climb>> Best rate of Climb 65> mph>>> Landing Approach>> Normal Approach 65> mph>> Touchdown speed 55> mph>>> Maximum Turbulent Air Penetration Speed 80 mph>>> Maximum Crosswind Velocity 10 mph>>> Engine Failure after takeoff 65 mph>>> Maneuvering speed>> 1150 lbs 80 mph>>> Maximum Glide 55 mph>>> Precautionary landing>> With engine power 55 mph>>> Landing without engine Power 55 mph>>> Vs Stall Speed 29 mph>>> Green Arc Normal Operating Range 29-80 mph>>> Yellow Arc Smooth Air Operating 80-100 mph>> Any thoughts from those already flying?>>> Blue Skies,>> Steve D>>> *>===========.matronics.com/Navigator?Pietenpol-List>======================om/contribution>===========>> *>>-- Semih Oksay________________________________________________________________________________Subject: Pietenpol-List: Light at the end of the tunnel...
Posted: Fri Oct 23, 2015 7:14 am
Original Posted By: "skipgadd(at)earthlink.net"
Hello gents. Last night my pietenpol looked the most like an airplane as it ever has. I finished the cabene struts and the center section was sitting in the corner so I threw it on for a picture. It made me realize how much closer I am to the finish line. The engine is sitting there waiting for a motor mount to be made, the fuel tank is patiently waiting to be installed, tailwheel is finished, wings are complete and ready to cover, wing struts are ready and the main landing gear is just about finished. Yippee Charles________________________________________________________________________________Date: Fri, 23 Oct 2015 07:40:17 -0400 (GMT-04:00)
Re: Pietenpol-List: Light at the end of the tunnel...
Posted: Fri Oct 23, 2015 9:22 am
Subject: Re: Pietenpol-List: Light at the end of the tunnel...
