Pietenpol-List: Source for smooth tires?
Posted: Fri Nov 27, 2015 10:10 am
I am putting together a new set of wire wheels, going the route of hubs from KenPerkins being laced to aluminum alloy wheels by Buchanan's. So far so good,but I have not been able to find smooth tires other than the Firestone SmoothClincher at Coker:https://www.cokertire.com/tires/styles/ ... .htmlThese fit a 1.77" rim, I'm not sure what diameter. I'm also not sure what "clincher"means. I know others have used the ribbed Avon M6 Speedmasters, for instance, they lookgreat on Jim Markle's build, but I like the look of the smooth tires. The Avonsare also fairly low profile and I like the look of a larger tire.Does anyone have sources or information on smooth tires?Thanks,JeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 27 Nov 2015 10:35:15 -0800
