Pietenpol-List: Some recent metalwork from the UK
Posted: Fri Mar 04, 2016 2:19 am
Original Posted By: "johnnysdrop"
> Clif- your Kung fu is better than mine...Ah, Grasshopper, that's because it's Qigong. :-)ClifHandle every Stressful situation like a dog.If you can't eat it or play with it,Piss on it and walk away.________________________________________________________________________________Subject: Pietenpol-List: Some recent metalwork from the UK
Re: Pietenpol-List: Some recent metalwork from the UK
Posted: Fri Mar 04, 2016 11:44 am
Original Posted By: Tony Crawford
Thanks Bill It was exciting to lay out the longhorns yesterday. BTW, I can't believe what SitkaSpruce costs these days... the truck showed up with my wood order and I kepttelling him " there has to be another box in there"... [Wink]Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 4 Mar 2016 15:27:44 -0600Subject: Re: Pietenpol-List: Some recent metalwork from the UK
Pietenpol-List: Re: Some recent metalwork from the UK
Posted: Sun Mar 13, 2016 1:37 pm
Oh, I just noticed that the seller says it turns over 360 degrees, so that mightindicate it hasn't thrown a rod or destroyed its insides.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Some recent metalwork from the UK
Re: Pietenpol-List: Re: Some recent metalwork from the UK
Posted: Wed Mar 16, 2016 10:50 am
Hi Phil,I see your trim tab. Mine is located in the rear most bay, under the horizontal. I have had mine for more than 30 years. It works very well. I have a tensionspring on one horn, a single cable going to the cockpit , attaching to thelever and another tension spring on the lever. The springs work against eachother to keep the cable tight. Very light weight. We got the idea of this type of trim tab from the Pre-war T-Craft. You will likeit. At this point I would consider moving yours back to the next bay. Itwill be more effective because of the longer arm. It will also be out of theway and people won't be walking into it. I believe there are pics of mine at
www.westcoastpiet.com Cheers,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 16 Mar 2016 14:05:48 -0500Subject: Re: Pietenpol-List: Re: Some recent metalwork from the UK
Posted: Thu Mar 17, 2016 3:38 am
Steve, shall I include the rest of the parts made [Exclamation]--------The only way is UPRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Thu, 17 Mar 2016 03:45:43 -0500Subject: Re: Pietenpol-List: Re: Some recent metalwork from the UK
