status of current build
Posted: Thu Feb 11, 2021 3:38 pm
by doug bryant
adding pics of current build. this will be cont powered, long fuse, cowings are also complete.
Re: status of current build
Posted: Fri Feb 12, 2021 7:06 pm
by doug bryant
cont engine mount tac weld fixture.
Posted: Sat Feb 13, 2021 9:52 am
by danoliver
It looks like you and I are at about the same stage. Where are you located? I'm in Cincinnati Ohio. Would be cool to get together.
Posted: Sat Feb 13, 2021 10:22 am
by doug bryant
im in wichita, ks. do u have pics?
Posted: Sat Feb 13, 2021 4:19 pm
by danoliver
I do.
Here’s a few.
Posted: Sat Feb 13, 2021 7:56 pm
by doug bryant
very nice work!! can't wait to see it flying. this one i am building is my 7th. i still need to build some of the tail feathers.
Posted: Sat Feb 13, 2021 8:03 pm
by tom kreiner
Dan,
Beautiful work, and beautiful work,a ship!
What is the angled blue steel strap at the rear end of the plywood on the S’board side of the fuselage?
Posted: Mon Feb 15, 2021 5:44 am
by danoliver
SEVENTH BUILD!
At some point I think you can no longer call it amateur built ha ha.
Could we get a photo montage of your life's work?
Tom, the blue fitting is just a U shaped strap for attaching a seat belt to.
Also, I was asked in a PM about the cable clamps on the center section cross bracing. These are temporary hardware store clamps, the airworthy versions will be swaged.
Posted: Wed Feb 24, 2021 9:13 am
by doug bryant
fuel tank complete and ready for filler neck. tank has stesrman type fuel gage.
Posted: Wed Feb 24, 2021 10:12 am
by taildrags
Which epoxy resin did you use on the fuel tank? Do you plan to run auto gas?
Air Camper NX41CC, A75 power, avgas
Posted: Wed Feb 24, 2021 10:51 am
by doug bryant
polyester resin; non-alcohol fuels. i have built a few tanks like this with great results.
Posted: Wed Feb 24, 2021 3:44 pm
by taildrags
OK. It's the alcohol blended autofuels that can cause problems. Sounds like you're all over it!
Posted: Thu Feb 25, 2021 10:08 am
by doug bryant
used top from a dried can of pvc glue for filler neck and cap. plywood template is the master tool for all the top division work
Posted: Thu Feb 25, 2021 10:58 am
by doug bryant
the loop is where the small chain will be attached.
Posted: Sun Mar 14, 2021 7:30 pm
by doug bryant
these are the hardest parts to make on the entire airplane; but got them done
Posted: Mon Mar 15, 2021 7:16 pm
by jdoucet
These are beautiful builds. It's almost a shame that we have to cover them to make them fly.
Posted: Tue Mar 16, 2021 3:33 pm
by doug bryant
that is very true
Posted: Sun Mar 21, 2021 5:58 pm
by doug bryant
completed tail feather fitting and rigging today. it was a productive day.
Posted: Sun Mar 28, 2021 6:40 pm
by doug bryant
started covering today
Posted: Sun Mar 28, 2021 11:28 pm
by KenBickers
Congratulations!! It's a great feeling to be at the covering stage. Suddenly the light at the end of the tunnel seems much brighter.
Posted: Mon Mar 29, 2021 6:31 pm
by doug bryant
all true! its a fun build!
Posted: Thu Apr 08, 2021 7:46 pm
by doug bryant
continuing to cover; tail feathers are almost done.
Posted: Thu Apr 08, 2021 10:50 pm
by taildrags
Careful... I see you've got that plane inverted. Note that the Air Camper is Normal category and only good for negative 1.52 G ;o)
-Oscar Z.
Posted: Fri Apr 09, 2021 8:41 am
by doug bryant
sure is easier to cover the bottom upside down though
Posted: Fri Apr 16, 2021 4:54 pm
by doug bryant
continuing covering, fuse, tail feathers,
Posted: Mon Apr 19, 2021 8:55 pm
by doug bryant
Posted: Mon Apr 26, 2021 9:18 am
by PoconoJohn
danoliver wrote: Sat Feb 13, 2021 4:19 pm
I do.
Here’s a few.
Oh gosh Danoliver! That's beautiful! Don't ever cover it!
Posted: Wed May 05, 2021 8:41 pm
by doug bryant
making small amounts of progress every day.
Posted: Fri May 07, 2021 8:21 am
by doug bryant
installing tail group next
Posted: Fri May 07, 2021 7:23 pm
by Richard Roller
Nice!
Posted: Thu May 20, 2021 7:49 pm
by doug bryant
more progress
Posted: Tue May 25, 2021 5:46 pm
by Piper
doug bryant wrote: Sat Feb 13, 2021 7:56 pm
I think one of my former employers bought avionics from the same place you did! (The local photocopy-shop.)
Posted: Tue Jun 15, 2021 9:44 pm
by doug bryant
engine instl started.
Posted: Sun Aug 22, 2021 6:02 pm
by doug bryant
completed more on engine, covered ailerons, wing ready for cover.
