Pietenpol-List: Inexpensive Hangars
On Wed, 6 May 1998, clawler wrote:> Ken,> > We just put up a pole building for the Piet. 32ft trusses. Green metal.> The hardest part was drilling the post holes. Recruted lots of help. Did> it in a weekend. Holds tractors and other farm stuff too. Less than> $3,000.> > Craig> Alonfg the same lines, I saw a hangar that had been built from 2x4 studs laminated together to form a 4x6 arches. They were then erected to form a quansit hut style hangar. The 2x4's were laminated using structural glue and bolts. It was then covered in corrugated panels. Nice little arrangment for a minimal cost.Ken________________________________________________________________________________
Pietenpol-List: RE: Inexpensive Hangars
Original Posted By: "Hixon, Carl"
The only problem that I have is that putting together a hanger at my airport requires me to get the building engineered, and I have to make the airport board happy, which is tough because they want the new bifold door steel buildings. they are expensive. They seem to want a whole row put in rather than onesy twosy. Bummer.SteveeOn Thursday, May 07, 1998 9:54 AM, Ken Beanlands [SMTP:ken.beanlands(at)west.gecems.com] wrote:> On Wed, 6 May 1998, clawler wrote:>> > Ken,> >> > We just put up a pole building for the Piet. 32ft trusses. Green metal.> > The hardest part was drilling the post holes. Recruted lots of help. Did> > it in a weekend. Holds tractors and other farm stuff too. Less than> > $3,000.> >> > Craig> >>> Alonfg the same lines, I saw a hangar that had been built from 2x4 studs> laminated together to form a 4x6 arches. They were then erected to form a > quansit hut style hangar. The 2x4's were laminated using structural glue> and bolts. It was then covered in corrugated panels. Nice little> arrangment for a minimal cost.>> Ken>________________________________________________________________________________
Yes. It is obvious that the folks with these inexpensive hangars arenot from California metropolitan areas! At Oceanside airport near myhome, the hangars are in terrible condition. The roofs leak, doors arerusted through etc. The roof is so unstable it isn't safe to walk upthere to repair the leaks. These hangars still cost about $300 permonth. Forget about building your own hangar or cover on the airport,the city would never approve it. That seems to be typical in San DiegoCounty. The only problem that I have is that putting together a hangerat my airport requires me to get the building engineered, and I haveto make the airport board happy, which is tough because they want the newbifold door steel buildings. they are expensive. They seem to want a wholerow put in rather than onesy twosy. Bummer. Stevee________________________________________________________________________________
I was very impressed with the hangers at Brodhead. They are all similar in appearance. I was wondering if the municipality or local airport authority builds them and leases them or is there some other way they are regulated. Owner built to standard on leased airport property? We have many ex WW11 airfields in western Canada but hanger space is expensive or non exsistant. I had thought of two retired forty foot semi trailers, minus undercarriage, spanned with rafters. One van could be a workshop and the other my home after AIDS* becomes terminal.AIDS- Aviation Induced Divorce SyndromeJ Mc ;-)________________________________________________________________________________
Pietenpol-List: Re: Inexpensive Hangars
I used the semi trailer idea in Puerto Rico for an Airline that I workedfor there. looks tacky but works.McNarry, John wrote:> I was very impressed with the hangers at Brodhead. They are all> similar in appearance. I was wondering if the municipality or local> airport authority builds them and leases them or is there some other> way they are regulated. Owner built to standard on leased airport> property? We have many ex WW11 airfields in western Canada but hanger> space is expensive or non exsistant.>> I had thought of two retired forty foot semi trailers, minus> undercarriage, spanned with rafters. One van could be a workshop and> the other my home after AIDS* becomes terminal.>> AIDS- Aviation Induced Divorce Syndrome>> J Mc ;-)--David B.Schober, CPEInstructor, Aviation MaintenanceFairmont State CollegeNational Aerospace Education CenterRt. 3 Box 13Bridgeport, WV 26330-9503(304) 842-8300________________________________________________________________________________
