Pietenpol-List: Rib Storage
Paris- Stack your ribs on some false spars of junk pine and SKIP thevarnish for now. The reason for this is that when you epoxy (or whatever glue you've chosen) the ribs you don't want varnish glued tovarnish, rather wood to wood joints. The varnish can be sprayed, brushedeasily later when you are done with all your glue joints. I'm sure you could varnish everything but where you'll need to glue but it's alot easierto do it later. Mike C. ________________________________________________________________________________
