If you have trouble finding those , my wife found small disposable clear plastic containers at a party supply house (something you might get an individual serving of mayo or butter in). I simply stacked one inside another, poured a known amount of fluid into the inner cup, marked the outer cup with a felt pen, then poured the same amount of fluid again and marked again. I keep the outer cup as a reference. When I want to mix glue I get a new inner cup, put it in my refernce cup, squeeze in one part up to the first line, then squeeze in the other part to the second line.>Date: Sat, 25 Jul 1998 07:20:02 -0400>From: Brad Schultz >Subject: Glue mixing>To: Pietenpol Discussion >Reply-to: Pietenpol Discussion >>Go to a medical supply house and buy some plastic pill cups. They>usually come in a tube of about 100 and are real cheap. They have all>kinds of markings on the side for oz's, cc's, etc. Just measure out>your T-88 50/50 and throw away the cup when you'r done. I've built>almost my whole plane this way and it works great.>>Brad Schultz>>Dean Dayton - deandayton(at)hotmail.com________________________________________________________________________________
