Pietenpol-List: Wing Leading Edge Cover
Original Posted By: Greg Yotz
Subject: Pietenpol-List: Wing Leading Edge Cover>As the plywood ( or metal) 9 inch strip covering the leading edge of the>wing is not required for structural support. It is rather an airfoil>support from what i can gather, the question of what may be a suitable>material arises.>>I have seen articles that advise not to use aluminum, as the transfer>line is too harsh (not aesthetic in nature).>>The use of 1/16 inch aircraft plywood appears to be ideal, except for>the cost. my calculation shows a 4' x 4' piece and a 2' x 4' piece cross>cut makes the least waste. The cost of this is likely going to be>US$100.>>I have looked at doorskins at $20 for material to do whole leading edge.>The down side is that they are 1/8" and heavier.>>I have looked for heavy (high density) cardboard, but have not found>anything useful.>>Any other suggestion?>For those of you that have used aluminum, would you do it again?>Has anyone used doorskins? Comments?>>Any help on this one would be appreciated.>-=Ian=->________________________________________________________________________________
Subject: Pietenpol-List: Wing Leading Edge Cover>As the plywood ( or metal) 9 inch strip covering the leading edge of the>wing is not required for structural support. It is rather an airfoil>support from what i can gather, the question of what may be a suitable>material arises.>>I have seen articles that advise not to use aluminum, as the transfer>line is too harsh (not aesthetic in nature).>>The use of 1/16 inch aircraft plywood appears to be ideal, except for>the cost. my calculation shows a 4' x 4' piece and a 2' x 4' piece cross>cut makes the least waste. The cost of this is likely going to be>US$100.>>I have looked at doorskins at $20 for material to do whole leading edge.>The down side is that they are 1/8" and heavier.>>I have looked for heavy (high density) cardboard, but have not found>anything useful.>>Any other suggestion? >For those of you that have used aluminum, would you do it again?>Has anyone used doorskins? Comments?>>Any help on this one would be appreciated.>-=Ian=->________________________________________________________________________________
Pietenpol-List: Re: Wing Leading Edge Cover
Original Posted By:>> Ian Holland
Subject: Pietenpol-List: Re: Wing Leading Edge Cover>Do you just dope the cardboard with epoxy after you get it in place? Orhow>do you insure enough regidity?>Do you glue it in place or use fasteners?>>Thanks,>>Greg Yotz>P.S. Got my Sport Aviation today... Anyone wanting me to email them a>digitized pict or Piet painting for wall paper please leave email address>here...>>John Greenlee wrote:>>> Ian,>>>> At the recommendation of builders of a Really nice, highly viewed Piet I>> used mat-board like for picture frames. Worked out really nice.>>>> The plans call for cardboard, and I have heard of campaign posters being>> used.>>>> John>>>> John>> -----Original Message-----
Ian,At the recommendation of builders of a Really nice, highly viewed Piet Iused mat-board like for picture frames. Worked out really nice.The plans call for cardboard, and I have heard of campaign posters beingused.JohnJohn-----Original Message-----
Original Posted By:> Ian Holland
Do you just dope the cardboard with epoxy after you get it in place? Or howdo you insure enough regidity?Do you glue it in place or use fasteners?Thanks,Greg YotzP.S. Got my Sport Aviation today... Anyone wanting me to email them adigitized pict or Piet painting for wall paper please leave email addresshere...John Greenlee wrote:> Ian,>> At the recommendation of builders of a Really nice, highly viewed Piet I> used mat-board like for picture frames. Worked out really nice.>> The plans call for cardboard, and I have heard of campaign posters being> used.>> John>> John> -----Original Message-----
A Gentleman in my EAA chapter that had the good fortune to spend sometime with Bernard Pietenpol many years ago told me that he used thecardboard from oatmeal containers ( the round quaker type ) to makehis leading edge. It might be hard to round up that many, but I knowsomeone that did it by scrounging for several weeks at a recyclingcenter...Paris---Ian Holland wrote:>> As the plywood ( or metal) 9 inch strip covering the leading edge ofthe> wing is not required for structural support. It is rather an airfoil> support from what i can gather, the question of what may be a suitable> material arises.> > I have seen articles that advise not to use aluminum, as the transfer> line is too harsh (not aesthetic in nature).> > The use of 1/16 inch aircraft plywood appears to be ideal, except for> the cost. my calculation shows a 4' x 4' piece and a 2' x 4' piececross> cut makes the least waste. The cost of this is likely going to be> US$100.> > I have looked at doorskins at $20 for material to do whole leadingedge.> The down side is that they are 1/8" and heavier.> > I have looked for heavy (high density) cardboard, but have not found> anything useful.> > Any other suggestion? > For those of you that have used aluminum, would you do it again?> Has anyone used doorskins? Comments?> > Any help on this one would be appreciated.> -=Ian=-> ________________________________________________________________________________
Greg,I think that's part of the idea. You don't want it TOO rigid. I just gluedit to the rib cap strips and varnished with the rest of the wing.John-----Original Message-----
As the plywood ( or metal) 9 inch strip covering the leading edge of thewing is not required for structural support. It is rather an airfoilsupport from what i can gather, the question of what may be a suitablematerial arises.I have seen articles that advise not to use aluminum, as the transferline is too harsh (not aesthetic in nature).The use of 1/16 inch aircraft plywood appears to be ideal, except forthe cost. my calculation shows a 4' x 4' piece and a 2' x 4' piece crosscut makes the least waste. The cost of this is likely going to beUS$100.I have looked at doorskins at $20 for material to do whole leading edge.The down side is that they are 1/8" and heavier.I have looked for heavy (high density) cardboard, but have not foundanything useful.Any other suggestion? For those of you that have used aluminum, would you do it again?Has anyone used doorskins? Comments?Any help on this one would be appreciated.-=Ian=-________________________________________________________________________________
>Do you just dope the cardboard with epoxy after you get it in place? Or how>do you insure enough regidity?>Do you glue it in place or use fasteners?>>Thanks,>>Greg Yotz>P.S. Got my Sport Aviation today... Anyone wanting me to email them a>digitized pict or Piet painting for wall paper please leave email address>here...>I would appreciate it.jas>John Greenlee wrote:>>> Ian,>>>> At the recommendation of builders of a Really nice, highly viewed Piet I>> used mat-board like for picture frames. Worked out really nice.>>>> The plans call for cardboard, and I have heard of campaign posters being>> used.>>>> John>>>> John>> -----Original Message-----
Ian, I have used aluminum on restorations of two Piper J-5 and have not hada problem with sharp definition. I believe you would see more withplywood, than Al.. I am going to use Al. leading edge support on the threepiece wing for my Piet.Phil Phillips
Original Posted By: Dean Dayton
Thanks for the feedback. I found a whole bunch of old file covers atwork (about 1940-50's vintage that are the same thickness as aluminumand are also very dense (glazed). They glue up well and I am now lookingat butt joints with a 1/2" "gusset"behind. I may yet look at aluminum.How did you fasten? by glue or?________________________________________________________________________________
Yes the 1.5mm aircraft birch I bought was about $24.00 4x4 sheet , Anderson's International has italso Westwind Hardwoods , International Hardwoodsin Detroit has very beautiful okoume 1/16 that is ($50 4x8)marine grade no knots very light and strong, the great thingis that they can be rolled up in a cylinder and shipped ups.all the above can be found on the internet. also Harborsales has very beautiful okoume,sapelee,khaya and birch in severaldifferent widths and grades free catalog 8008689257 I recently found baltic birch plywood in 1/8 and 1/4 in in local hardware store 50"x50" inches for $12.00 a sheet, very strong, failsin wood not glue line, I also purchased hollow core interiordoors that were damaged form a local hardware storefor $2.00 a piece, ripped the edges off with a table saw then slowly pryed apart while cutting card board spacingwith hand saw, not bad stuff left outside a week with a coupleof rains with no delamination. width is about 1/16" A light sanding withmed grade paper will remove the cardboard and gluefrom inside section of ply. I'm no expert but if you ever hadto force land in a corn field I believe the damages wouldbe much easier to repair on a ply leading edge than one builtof sheet aluminum.-----Original Message-----
Hello to the group,i used 1.5mm 3 ply birch for my leading edgecover.Soaked in hot water in the sink for 1/2 hour or so,then was able tostart the ply at the bottom edge of the leading edge and wrap it around andstopped about 3 inches past the spar at the top.I secured it to the wingover night with strips or wood and bungee straps,then removed it the nextday,it retained its shape,then applied epoxy and held it in place againwith the strips of wood untill set.I then cut scallops in the ply betweenthe ribs at the top for visual apeal (to my eyes anyway).I epoxied stripsof high density styrofoam on top of the spar to support the light ply.Ialso cut false nose ribs and epoxied them to the inside of the leading plyto give more support as i found without it,the ply did not lay true.I think if i was to do it again i would consider aluminum,far less labour? I also routed out the back side of the leading edge before i installedit,saving 1.5 lbs.per wing. For what it's worth......Doug Hunt.............
Original Posted By: William Conway
Care to share your source? I priced 1/16 plywood for that job and nearly split a gasket.On 16 Sep 98 at 12:04, Ian Holland wrote:> Thanks to all that responded. After gluing a bunch of the card file> material together, I have abandonned the idea of using it due to the> lack of rigidity and seams. I am now proceeding with aluminum. > > I found a good source $25 for enough to do the entire leading edge.> > Currently I am planning on doing 1/2 inch nailing along the nose> piece and along the built up spar. I was thinking of using the 1/2> inch aircraft nails as I have a lot of them left. > > Is this the right way to do it, or should I be doing something else?> also, does the aluminum go directly in contact with the wood, or is> there tape between? I am planning on two coat epoxy varnishing the> wing before applying the aluminum leading edge. > > Can't seem to find anything in the manuals on how to do this.> Richard DeCostaWeb/CGI Programming - Auto Europe, LLC Web: http://www.autoeurope.com Ph: 207-842-2064 Fax: 207-842-2239PERSONAL: http://207.140.1.221/w3builder_________ ... __________
I used the aluminum and think it looks great: smooth, estheticallypleasing. I used epoxy varnish, as you suggest, and then nailed the LEdirectly, just as you plan to do. I used tape afterwards on the nails andjoints to prepare the surface for fabric. I personally think Bernie wouldhave used aluminum today.>>> Ian Holland 09/16 1:04 PM >>>Thanks to all that responded. After gluing a bunch of the card filematerial together, I have abandonned the idea of using it due to thelack of rigidity and seams. I am now proceeding with aluminum.I found a good source $25 for enough to do the entire leading edge.Currently I am planning on doing =BD inch nailing along the nose pieceand along the built up spar. I was thinking of using the =BD inchaircraft nails as I have a lot of them left.Is this the right way to do it, or should I be doing something else?also, does the aluminum go directly in contact with the wood, or isthere tape between? I am planning on two coat epoxy varnishing the wingbefore applying the aluminum leading edge.Can't seem to find anything in the manuals on how to do this.________________________________________________________________________________
Original Posted By: "Richard DeCosta"
Thanks to all that responded. After gluing a bunch of the card filematerial together, I have abandonned the idea of using it due to thelack of rigidity and seams. I am now proceeding with aluminum. I found a good source $25 for enough to do the entire leading edge.Currently I am planning on doing 1/2 inch nailing along the nose pieceand along the built up spar. I was thinking of using the 1/2 inchaircraft nails as I have a lot of them left. Is this the right way to do it, or should I be doing something else?also, does the aluminum go directly in contact with the wood, or isthere tape between? I am planning on two coat epoxy varnishing the wingbefore applying the aluminum leading edge. Can't seem to find anything in the manuals on how to do this.________________________________________________________________________________
Original Posted By: scherer2(at)airmail.net (Glenn Scherer)
The source was old files at work, namely Control Department files thatwere obsolete. They were old filing jackets of very dense (glazed) paperboard that were almost like arborite but not as stiff.in 9 x 12 format.they glued up real well. the trick would be to go to the source and trieto get a stub roll of the stuff before they were cut up. I suspect thatthe stuff is no longer made.I went to the Beaver lumber store and for $9.00 Canadian, got 14" x 10'aluminum flashing. $30 for the whole works.The name of the material that I think would do a good job is;ACCOPRESSGenuine pressboard binderAcco Canadian Company LtdTorontoalso ogdensburg,N.Y, Chicago, londonI went to the local Home Businesss store, but could not find anythingsimilar. All the new stuff is pretty cheap and flimsey looking comparedto the above.Yeah, the cost of 1/16 ply set me back on my heels too!Good luck,-=Ian=-________________________________________________________________________________
> Subject: Wing Leading Edge Cover>> >As the plywood ( or metal) 9 inch strip covering the leading edge of the> >wing is not required for structural support. It is rather an airfoil> >support from what i can gather, the question of what may be a suitable> >material arises.> >> >I have seen articles that advise not to use aluminum, as the transfer> >line is too harsh (not aesthetic in nature).> >> >The use of 1/16 inch aircraft plywood appears to be ideal, except for> >the cost. my calculation shows a 4' x 4' piece and a 2' x 4' piece cross> >cut makes the least waste. The cost of this is likely going to be> >US$100.> >> >I have looked at doorskins at $20 for material to do whole leading edge.> >The down side is that they are 1/8" and heavier.> >> >I have looked for heavy (high density) cardboard, but have not found> >anything useful.> >> >Any other suggestion?> >For those of you that have used aluminum, would you do it again?> >Has anyone used doorskins? Comments?> >> >Any help on this one would be appreciated.> >-=Ian=-> >________________________________________________________________________________
Original Posted By: PTNPOL(at)aol.com
>> Subject: Wing Leading Edge Cover>>>> >As the plywood ( or metal) 9 inch strip covering the leading edge of the>> >wing is not required for structural support. It is rather an airfoil>> >support from what i can gather, the question of what may be a suitable>> >material arises.>> >>> >I have seen articles that advise not to use aluminum, as the transfer>> >line is too harsh (not aesthetic in nature).>> >>> >The use of 1/16 inch aircraft plywood appears to be ideal, except for>> >the cost. my calculation shows a 4' x 4' piece and a 2' x 4' piece cross>> >cut makes the least waste. The cost of this is likely going to be>> >US$100.>> >>> >I have looked at doorskins at $20 for material to do whole leading edge.>> >The down side is that they are 1/8" and heavier.>> >>> >I have looked for heavy (high density) cardboard, but have not found>> >anything useful.>> >>> >Any other suggestion?>> >For those of you that have used aluminum, would you do it again?>> >Has anyone used doorskins? Comments?>> >>> >Any help on this one would be appreciated.>> >-=Ian=->> >>>________________________________________________________________________________
Original Posted By: Jim Sury
Original Posted By: oil can
> > As the plywood ( or metal) 9 inch strip covering the leading edge of the> wing is not required for structural support. It is rather an airfoil> support from what i can gather, the question of what may be a suitable> material arises.> > I have seen articles that advise not to use aluminum, as the transfer> line is too harsh (not aesthetic in nature).> > The use of 1/16 inch aircraft plywood appears to be ideal, except for> the cost. my calculation shows a 4' x 4' piece and a 2' x 4' piece cross> cut makes the least waste. The cost of this is likely going to be> US$100.> > I have looked at doorskins at $20 for material to do whole leading edge.> The down side is that they are 1/8" and heavier.> > I have looked for heavy (high density) cardboard, but have not found> anything useful.> > Any other suggestion? > For those of you that have used aluminum, would you do it again?> Has anyone used doorskins? Comments?> > Any help on this one would be appreciated.> -=Ian=-________________________________________________________________________________
> > Thanks for the feedback. I found a whole bunch of old file covers at> work (about 1940-50's vintage that are the same thickness as aluminum> and are also very dense (glazed). They glue up well and I am now looking> at butt joints with a 1/2" "gusset"behind. I may yet look at aluminum.> How did you fasten? by glue or?________________________________________________________________________________
