Pietenpol-List: span-wise tapes
Original Posted By: fishin
Good evening, y'all,I'm getting ready to install span-wise tapes to my left wing. Where alldid you put them? The leading edge and trailing edge are obvious as isthe leading edge sheeting. Did you add any over any of the other spars?Need info.JohnGood evening, y'all,I'm getting ready to install span-wise tapes to myleftwing. Where all did you put them? The leading edge andtrailing edgeare obvious as is the leading edge sheeting. Did you add any overany ofthe other spars?Need info.John________________________________________________________________________________
