Pietenpol-List: Piet Value???
Original Posted By: William Conway
What do you think a used Piet would be worth in the following config???Built 1986 and in good shape.Cont. 0-65 w/wood prop.Recovered in 1996.Basic instr.Good paint job.The artistic wood areas are of 'pretty good' quality.This is not a champion at Osh. but also not a dog.Any comments????thanks,GY________________________________________________________________________________
Pietenpol-List: Re: Piet Value???
Original Posted By: bozeman(at)cassnet.com (Bozeman, Eli, Robert, and Teresa)
I'd guess around $8,000, depending a little on how close the engine is tooverhaul. The plane may have sat outside: I can't image the need forrecover in just 10 years. Even though I would like to think our labor isworth something, I think in general we're likely to get about the cost ofour materials and only a few pennies per hour. Of course, for me, thebuilding is a great pleasure and I usually don't get paid to have fun!>>> Greg Yotz 09/21 7:49 AM >>>What do you think a used Piet would be worth in the following config???Built 1986 and in good shape.Cont. 0-65 w/wood prop.Recovered in 1996.Basic instr.Good paint job.The artistic wood areas are of 'pretty good' quality.This is not a champion at Osh. but also not a dog.Any comments????thanks,GY________________________________________________________________________________
I concur with William and actually saw an ad for a A-65 powered Piet for$12,000 CDN ( about $8000 USD) on the weekend.On Mon, 21 Sep 1998, William Conway wrote:> I'd guess around $8,000, depending a little on how close the engine is> to overhaul. The plane may have sat outside: I can't image the need for>>> Greg Yotz 09/21 7:49 AM >>>>> What do you think a used Piet would be worth in the following config???> > Any comments????> > thanks,> GY________________________________________________________________________________
