Pietenpol-List: Wing cut out
David B. Schober wrote:heraised the wing. I've seen pictures of airplanes with the wing 2" and 4"higher than the plans. The 2" extension looks the best. Another sollutionisto hinge the trailing edge of the center section so you can lift it up togetin and out and then set it back in position for flight.>I did excatly that. My wing is raised 2.5 inches & 3.5 inches back from thevertical. ( 0-200 up front ). The center section hinged trailing edge (Bernard called it a flop ) dimensions are: 3 ft 8.25 inches X 12 inches.The flop extends one bay into the left wing. The flop is attached via apiano hinge to a false spar.Mike ( Piet ( N 687 MB )________________________________________________________________________________
