Original Posted By: "Larsen, Ed"
I have two things I'd like to discuss. As I wrote previously, I have thecutout in my wing and feel that it is absolutely necessary for access tothe cockpit and for visability. I have my radiator tucked under the FordEscort; just think what the turbulence must be off the Model-A radiatorfacing the wind squarely in front of the center section of the wing. Justhow efficient can that center section be in the Model A versions? Cuttingsome 3 or 3 =BD square feet out of the wing equals a lose of just thatamount, particularly on the trailing edge. Last evening as I was flying Ialso found out that my crash helmet sticks some 1 or 2 inches up into thecut out area. For someone my height, 6'2", the cabane struts would haveto be lengthened to gain clearance. I can't image lowering the seat anybecause my legs are reasonably tight now. Of course, if I didn't use acushion at all, I'd be 1/2 " lower. When turning base on approach, I lovebeing able to look under the wing and over it at the same time. I feelthe safety factor, alone is worth the lose of a few square feet of wing. I do have a problem I could use some suggestions on. The Ford Escort withstraight pipes is pretty loud--probably an understatement! With tightearphones in my crash helmet, it doesn't bother me at all. I need asimple, compact way to cut the noise down some without losing itsdistinctive sound. I have all four exhaust pipes going into a single tubewhich is around 2 =BD or 3 inches in diameter--can't remember exactly. Idon't want to add anything with much leverage because of the vibration andcracking. I've heard that a motorcycle spark arrestor might cut the noisea little. I don't want to got to a full exhaust system with a bulkymuffler hanging in the airstream such as some of the 2-stroke people have. Suggestions???________________________________________________________________________________
Pietenpol-List: Wing cutout and engine noise
Pietenpol-List: Re: Wing cutout and engine noise
William Conway wrote:> I have two things I'd like to discuss. As I wrote previously, I have t=he cutout in my wing and feel that it is absolutely necessary for accessto the cockpit and for visability. I have my radiator tucked under the F=ord Escort; just think what the turbulence must be off the Model-A radiat=or facing the wind squarely in front of the center section of the wing. J=ust how efficient can that center section be in the Model A versions? Cut=ting some 3 or 3 =BD square feet out of the wing equals a lose of just t=hat amount, particularly on the trailing edge. Last evening as I was fly=ing I also found out that my crash helmet sticks some 1 or 2 inches up in=to the cut out area. For someone my height, 6'2", the cabane struts woul=d have to be lengthened to gain clearance. I can't image lowering the se=at any because my legs are reasonably tight now. Of course, if I didn'tuse a cushion at all, I'd be 1/2 " lower. When turning base on approach,= I love being able to look under the wing and over it at the same time. I feel the safety factor, alone is worth the lose of a few square feet of= wing.>> I do have a problem I could use some suggestions on. The Ford Escort w=ith straight pipes is pretty loud--probably an understatement! With tight= earphones in my crash helmet, it doesn't bother me at all. I need a si=mple, compact way to cut the noise down some without losing its distincti=ve sound. I have all four exhaust pipes going into a single tube which i=s around 2 =BD or 3 inches in diameter--can't remember exactly. I don'twant to add anything with much leverage because of the vibration and crac=king. I've heard that a motorcycle spark arrestor might cut the noise alittle. I don't want to got to a full exhaust system with a bulky muffle=r hanging in the airstream such as some of the 2-stroke people have. Sug=gestions???Bill,On the off-chance you're not aware, the Tony Bingelis book FIREWALL FORWA=RD has about 25 pages devoted to exhausts & mufflers. Part of it is theo=ry and the rest is applications. It's available thru EAA, Spruce & Speci=alty, probably Sportys, etc. About20 bucks if I recall. If you haven't seen it and just want the exhaust/m=uffler section, let me know you're snail-mail and I'll copy it at the off=ice after Thanksgiving & get it to you.Lee in MIP.S. To Mike Cuy: I've been lurking here for over a year; I coveted you=r ship at Brodhed '98 (my 3rd gettin'-ready-to-get-ready trip) and I valu=e the insights & thoughts you send out- Keep it up!.......________________________________________________________________________________
William,A friend of mine has suggested installing an internal type spark/nois=earrestor as was used in VW's. Take a thin sheet of stainless about th=elength of your straight section. Take a 3/16 inch dia. nail and punch= holesinto the entire sheet. role the sheet so the sharp side if the holesareagainst the exhaust flow. Set the roled sheet on stand-offs inside yo=ueexhaust, and keep it in place with a few stainless machine screws. Th=isshould work. I'll be doing just this for my corvair.regards,Dom. Bellissimo-----Original Message-----=46rom: William Conway Date: Tuesday, November 24, 1998 11:58 AMSubject: Pietenpol-List: Wing cutout and engine noise>I have two things I'd like to discuss. As I wrote previously, I hav=e thecutout in my wing and feel that it is absolutely necessary for access= to thecockpit and for visability. I have my radiator tucked under the FordEscort; just think what the turbulence must be off the Model-A radiat=orfacing the wind squarely in front of the center section of the wing.Justhow efficient can that center section be in the Model A versions? Cut=tingsome 3 or 3 =BD square feet out of the wing equals a lose of just th=atamount, particularly on the trailing edge. Last evening as I was fly=ing Ialso found out that my crash helmet sticks some 1 or 2 inches up into= thecut out area. For someone my height, 6'2", the cabane struts would h=ave tobe lengthened to gain clearance. I can't image lowering the seat anybecause my legs are reasonably tight now. Of course, if I didn't use= acushion at all, I'd be 1/2 " lower. When turning base on approach, I= lovebeing able to look under the wing and over it at the same time. I fe=el thesafety factor, alone is worth the lose of a few square feet of wing.>>I do have a problem I could use some suggestions on. The Ford Escor=t withstraight pipes is pretty loud--probably an understatement! With tightearphones in my crash helmet, it doesn't bother me at all. I need asimple, compact way to cut the noise down some without losing itsdistinctive sound. I have all four exhaust pipes going into a single= tubewhich is around 2 =BD or 3 inches in diameter--can't remember exactly=. Idon't want to add anything with much leverage because of the vibratio=n andcracking. I've heard that a motorcycle spark arrestor might cut thenoise alittle. I don't want to got to a full exhaust system with a bulky mu=fflerhanging in the airstream such as some of the 2-stroke people have.Suggestions???>>________________________________________________________________________________
Ian, I have a 1986 1.9L Ford Escort in my plane. It is converted usingthe conversion kit once marketed by Ed. Libtz, a Canadian Airline Pilot. I probably didn't spell his name correctly. As far as I know the kitisn't available any longer. Basically, the engine is turned around, thedistributor is moved and operated by a 1 to 1 cogbelt from the overheadcam pully on the serpentine belt end of the engine. A cast iron 2.5 to 1reduction psru is created on the other end. Basically a small cog pullyis bolted to the center of the flywheel and a larger one to the front ofthe engine using just two bolts and a spindle with tapered bearings. Theprop is bolted directly to the larger cog pully. My unit has about 66hours flying time with no major problems. The carb is modified slightlybut other wise the engine is stock with both starter and alternator. Total weight is around 300 lbs with around 80 hp. My plane solo takes offin 2-300 feet and climbs like crazy; this is from a strip located at 4860feet altitude. >>> Ian Holland 11/25 11:24 AM >>>Hi! I have been following the discussion with interest, particularlyregarding the use of the Ford Escort engine. Is there anything that youcan share with how to convert/use as an aircraft engine? Year, type,power, type of reduction etc? Corvairs are getting darn hard to find!________________________________________________________________________________
