Pietenpol-List: Screen Saver
Screen Saver
Original Posted By: Rob Hart
Subject: Screen Saver To: Anyone interested, In answer to several observed items in this discussion group, I havecompiled a Pietenpol Screen Saver. If you are interested in having arepeating slide show of Pietenpol Aircraft on your computer, RichardDeCosta will have it available on his terrific Web Site. I hope you enjoy it as much as I do. I have installed it on fourmachines in Oregon and Washington. All of which are owned by hopefulPietenpol builders. For those of you who own the planes in the photographs, Thank Youfor letting the rest of us share your dream machines. If you do like the Screen Saver there will be another versionavailable as soon as I get all the images in a story telling sequence. Enjoy and Continue the Dream, Ron Gipson________________________________________________________________________________
Subject: Pietenpol-List: Screen Saver>I've been checking out the discussion group and there's sure a lot of good>information here. Seems like there's a lot of Piet building experiencehere>too. Can any one tell me where I can get some pretty specific informationon>using a Model A Ford engine in a Pietenpol? I would really like to trythis>out but all I have been able to get so far for information has been really>general. What sort of modifications does one need to make to the stockModel>A engine, how do you fit a prop hub, (what kind of prop seems to workbest),>how about motor mounts, etc. etc. ad nauseum. Anyone there had anyexperience>or know if there are any plans available for converting the engine?>________________________________________________________________________________
Original Posted By: JKend81933(at)aol.com
In answer to several observed items in this discussion group, I havecompiled a Pietenpol Screen Saver. If you are interested in having arepeating slide show of Pietenpol Aircraft on your computer, RichardDeCosta will have it available on his terrific Web Site.I hope you enjoy it as much as I do. I have installed it on fourmachines in Oregon and Washington. All of which are owned by hopefulPietenpol builders.For those of you who own the planes in the photographs, Thank You forletting the rest of us share your dream machines.If you do like the Screen Saver there will be another version availableas soon as I get all the images in a story telling sequence.Enjoy and Continue the Dream,Ron Gipson________________________________________________________________________________
I've been checking out the discussion group and there's sure a lot of goodinformation here. Seems like there's a lot of Piet building experience heretoo. Can any one tell me where I can get some pretty specific information onusing a Model A Ford engine in a Pietenpol? I would really like to try thisout but all I have been able to get so far for information has been reallygeneral. What sort of modifications does one need to make to the stock ModelA engine, how do you fit a prop hub, (what kind of prop seems to work best),how about motor mounts, etc. etc. ad nauseum. Anyone there had any experienceor know if there are any plans available for converting the engine?________________________________________________________________________________
Pietenpol-List: Re: Screen Saver
The Model A engine doen't need vey much in the way of mods to power a Piet.It does however need to be in very good condition. It takes 33 HP to meetminimum Canadian Climb specs in a Piet. A Model A in good shape can produce40hp.I suggest you find the nearest Model A Ford Club of America chapter (checkout the BPA website) The stock Ford crank has a long rear main (which now is the front main) tocarry the heavy flywheel used in the Model A. The length is comparable to asmall continental. The output is a four bolt flange. The most logical wayI've seen to fit a prop fitted is by using an adapter machined to theLycoming or Continental six bolt circle. The advantage of this is that moreprops are available if you need one in a hurry. The other major changes areto the oiling system and ignition systems. The Flying and Gliding manualscover this in adaquate detail.If you need more engine specs feel free to contact me.John Mc-----Original Message-----
The 1932 Flying & Glider Manual available from the EAA (for under tenBucks) has all the info you need. If you Decide to build though Ireccomend Buying the full size Plans from the Pietenpol Family, they area lot easier to use. The Mods are all fairly easy. The Motor mount isvery basic but effective.Good luckJohn DupreyJKend81933(at)aol.com wrote:> > I've been checking out the discussion group and there's sure a lot of good> information here. Seems like there's a lot of Piet building experience here> too. Can any one tell me where I can get some pretty specific information on> using a Model A Ford engine in a Pietenpol? I would really like to try this> out but all I have been able to get so far for information has been really> general. What sort of modifications does one need to make to the stock Model> A engine, how do you fit a prop hub, (what kind of prop seems to work best),> how about motor mounts, etc. etc. ad nauseum. Anyone there had any experience> or know if there are any plans available for converting the engine?________________________________________________________________________________
Subject: Pietenpol-List: Re: Screen SaverCouldn't have said it better myself, Brent. A great piece of workfrom Ron and Richard. I've even convinced the network administratorat work to leave it on our dept. PCsRobOz Piets: nearly the only ones to fly inverted...________________________________________________________________________________
Original Posted By: Ron Gipson
I haven't seen anyone mention the screen saver at Richard's site so Iwill put my two cents in. I have it on my machine and every time I seethat it has started I see all the beautiful work many of you havecreated. It constantly reminds me of my goal, as far off at that seems. If you haven't tried it I would recommend it. It is FREE to ANYONE andnicely put together. I hope this shameless recommendation for thescreen saver my father-in-law, Ron Gipson, created will get you to tryit. Really, it's very cool.:)Here it is.http://207.140.1.221/w3builder/piet/scr ... zipWARNING! 5.3 MB!!Brent Reed -----Original Message-----
Couldn't have said it better myself, Brent. A great piece of work from Ron and Richard. I've even convinced the network administrator at work to leave it on our dept. PCsRobOz Piets: nearly the only ones to fly inverted...________________________________________________________________________________
It is on my desktop at work. I really like looking up and seeing it when Ineed to rest my eyes. Inspiration to finish the job!John Mc-----Original Message-----
Original Posted By:> Ron Gipson
A wonderful screensaver. Thanks to your Father-in-Law for building it andto Richard DeCosta for making it available to all of us! This NG is great.Al Swanson>I haven't seen anyone mention the screen saver at Richard's site so I willput my two cents in. I have it on my machine and every time I see that ithas started I see all the beautiful work many of you have created. Itconstantly reminds me of my goal, as far off at that seems. If you haven'ttried it I would recommend it. It is FREE to ANYONE and nicely puttogether. I hope this shameless recommendation for the screen saver myfather-in-law, Ron Gipson, created will get you to try it. Really, it'svery cool.
>>Here it is. >http://207.140.1.221/w3builder/piet/scr ... ip>WARNING! 5.3 MB!!>>>Brent Reed> -----Original Message-----
> Screen Saver
> Subject: Screen Saver> > > To: Anyone interested,> > In answer to several observed items in this discussion group, I havecompiled a Pietenpol Screen Saver. If you are interested in having arepeating slide show of Pietenpol Aircraft on your computer, Richard DeCostawill have it available on his terrific Web Site.> I hope you enjoy it as much as I do. I have installed it on fourmachines in Oregon and Washington. All of which are owned by hopefulPietenpol builders.> For those of you who own the planes in the photographs, Thank You forletting the rest of us share your dream machines.> If you do like the Screen Saver there will be another version availableas soon as I get all the images in a story telling sequence.> > Enjoy and Continue the Dream,> Ron Gipson>________________________________________________________________________________
