Original Posted By: Seibert
Nearing the first flights of the spring. Smoke system installed and new800x6 tires. Soon life will have meaning again. PS. don't tell duane thatI have smoke... Heh heh won't he be surprised....BTW ATF doesn't smoke up all that well from my ground tests. Vegi oil isnext.Steve EldredgeSteve(at)byu.eduIT ServicesBrigham Young University________________________________________________________________________________
Pietenpol-List: Wings back on...
Pietenpol-List: Re: Wings back on...
>> Steve- Robert H. and I have discussed substitutes for the Texaco Canopus No.> 13oil used for smoke by the airshow folks....and after looking at the chemicalpropertieslisted under Texaco's web page it looks like a close match might be a lightweightmineral oil. You might want to try that if the vegi oil doesn't work. Mike C. >> (although it's not cheap, the Texaco stuff works GREAT !!)Steve- Robert H. and I have discussedsubstitutes for the Texaco Canopus No. 13oil used for smokeby the airshow folks....and after looking at the chemical propertieslisted under Texaco's web page it looks like a close match might be alight weightmineral oil. You might want to try that if the vegi oil doesn'twork. Mike C. (although it's not cheap,the Texaco stuff works GREAT !!)________________________________________________________________________________
Original Posted By: Wayne and Kathy
steve(at)byu.edu wrote:> > Nearing the first flights of the spring. Smoke system installed and> new 800x6 tires. Soon life will have meaning again. PS. don't tell> duane that I have smoke... Heh heh won't he be surprised....> > BTW ATF doesn't smoke up all that well from my ground tests. Vegi> oil is next.> > > Steve Eldredge> Steve(at)byu.edu> IT Services> Brigham Young University> Hi Steve ; You may want to try diesel fuel , the heating oil type is fine and fora little extra you can add a few oz. of creasote. This is a chemicalused to treat and preserve wood or in cement plants for a releaseagent. I also have just put my wings on and will soon be airborne.Wayne Tokarz________________________________________________________________________________
Oh how sweet it is to get back up in the air. If I had come back to workthis morning without having gone flying this weekend, reading about Dom'sfirst flight and Roberts new plane flights, it would have driven me to getgone to the airport! It is going to be great. Duane and I went upformation for over an hour and I gave him a burst of smoke. You should haveseen him lite up. He thought I was going down! I had told him that Iwanted to do a couple touch and goes before we headed to to sod farm. Hejoined up with me after a round or to, and just as he formed up I hit thesmoke, hesitated and peeled off back toward the airport. He was rightbehind me and sweating for me until I turned it off and straightened out.We flew around west mountain and smoked the fishermen on Utah lake. Landedat our favorite 1600' sod farm between the wheel lines. The grass had beenfresh cut and cast up shallow green clipping roosters as we blasted off.Can't wait to go again.SteveeSteve EldredgeIT ServicesBrigham Young University> -----Original Message-----> Wayne and Kathy> Sent: Friday, April 16, 1999 5:24 PM> To: Pietenpol Discussion> Subject: Re: Wings back on...>>> steve(at)byu.edu wrote:> >> > Nearing the first flights of the spring. Smoke system installed and> > new 800x6 tires. Soon life will have meaning again. PS.> don't tell> > duane that I have smoke... Heh heh won't he be surprised....> >> > BTW ATF doesn't smoke up all that well from my ground tests. Vegi> > oil is next.> >> >> > Steve Eldredge> > Steve(at)byu.edu> > IT Services> > Brigham Young University> >>>> Hi Steve ;> You may want to try diesel fuel , the heating oil type is> fine and for> a little extra you can add a few oz. of creasote. This is a chemical> used to treat and preserve wood or in cement plants for a release> agent. I also have just put my wings on and will soon be airborne.>> Wayne Tokarz>________________________________________________________________________________
So, let me get this strait, you have no electric system, but you do havethe luxury of a smoke system?!? ;-)You should check with Dick Starks and the gang to see what they use inthier Neiports for smokin'. With the way he writes, I suspect that it maybe Canabus, not Canopus
. Thier web page is athttp://www.kcdawnpatrol.org/ and theyt seem to be able to produce quite abut of smoke with the little VW engines.Ken.On Mon, 19 Apr 1999 steve(at)byu.edu wrote:> Oh how sweet it is to get back up in the air. If I had come back to work> this morning without having gone flying this weekend, reading about Dom's> first flight and Roberts new plane flights, it would have driven me to get> gone to the airport! It is going to be great. Duane and I went up> formation for over an hour and I gave him a burst of smoke. You should have> seen him lite up. He thought I was going down! I had told him that I> wanted to do a couple touch and goes before we headed to to sod farm. He> joined up with me after a round or to, and just as he formed up I hit the> smoke, hesitated and peeled off back toward the airport. He was right> behind me and sweating for me until I turned it off and straightened out.> We flew around west mountain and smoked the fishermen on Utah lake. Landed> at our favorite 1600' sod farm between the wheel lines. The grass had been> fresh cut and cast up shallow green clipping roosters as we blasted off.> Can't wait to go again.> > Stevee> > Steve Eldredge> IT Services> Brigham Young University> > > > -----Original Message-----> > Wayne and Kathy> > Sent: Friday, April 16, 1999 5:24 PM> > To: Pietenpol Discussion> > Subject: Re: Wings back on...> >> >> > steve(at)byu.edu wrote:> > >> > > Nearing the first flights of the spring. Smoke system installed and> > > new 800x6 tires. Soon life will have meaning again. PS.> > don't tell> > > duane that I have smoke... Heh heh won't he be surprised....> > >> > > BTW ATF doesn't smoke up all that well from my ground tests. Vegi> > > oil is next.> > >> > >> > > Steve Eldredge> > > Steve(at)byu.edu> > > IT Services> > > Brigham Young University> > >> >> >> > Hi Steve ;> > You may want to try diesel fuel , the heating oil type is> > fine and for> > a little extra you can add a few oz. of creasote. This is a chemical> > used to treat and preserve wood or in cement plants for a release> > agent. I also have just put my wings on and will soon be airborne.> >> > Wayne Tokarz> >> ________________________________________________________________________________
> RE: Wings back on...
Original Posted By:> > > Maiser(at)adena.byu.edu
Isn't it cool! No electrics and smoke! Borrowed the idea from Mike Cuy inusing a manual pump up insecticide spray bottle. Just fill, pump topressurize and connect. Very simple very beautiful. (also very economical!)Steve EldredgeIT ServicesBrigham Young University> -----Original Message-----> Behalf Of Ken> Beanlands> Sent: Monday, April 19, 1999 11:09 AM> To: Pietenpol Discussion> Subject: RE: Wings back on...>>> So, let me get this strait, you have no electric system, but> you do have> the luxury of a smoke system?!?
>> You should check with Dick Starks and the gang to see what they use in> thier Neiports for smokin'. With the way he writes, I suspect> that it may> be Canabus, not Canopus
. Thier web page is at> http://www.kcdawnpatrol.org/ and theyt seem to be able to> produce quite a> but of smoke with the little VW engines.>> Ken.>> On Mon, 19 Apr 1999 steve(at)byu.edu wrote:>> > Oh how sweet it is to get back up in the air. If I had> come back to work> > this morning without having gone flying this weekend,> reading about Dom's> > first flight and Roberts new plane flights, it would have> driven me to get> > gone to the airport! It is going to be great. Duane and I went up> > formation for over an hour and I gave him a burst of smoke.> You should have> > seen him lite up. He thought I was going down! I had> told him that I> > wanted to do a couple touch and goes before we headed to to> sod farm. He> > joined up with me after a round or to, and just as he> formed up I hit the> > smoke, hesitated and peeled off back toward the airport.> He was right> > behind me and sweating for me until I turned it off and> straightened out.> > We flew around west mountain and smoked the fishermen on> Utah lake. Landed> > at our favorite 1600' sod farm between the wheel lines.> The grass had been> > fresh cut and cast up shallow green clipping roosters as we> blasted off.> > Can't wait to go again.> >> > Stevee> >> > Steve Eldredge> > IT Services> > Brigham Young University> >> >> > > -----Original Message-----
