Subject: Pietenpol-List: 'A' pistons>What kind of pistons do you 'A' guys you when you rebuild?>>Richard>>My homepage: http://www.AirCamper.org/w3builder>....Oh that I had wings like a dove! for then would I fly away, and beat rest. -Psalm 55:6>--------------------------------------------------------->Visit www.AirCamper.org - A Low 'n Slow Online Community!>--------------------------------------------------------->____>Free instant messaging and more at http://messenger.yahoo.comRichard There are two choices for pistons of the Avariety. Fordalways used what are refered to as cam ground pistons. Theyhave asymetrical cam shape when cold and expand alond the wrist pin to becomecylindrical when at operating temp. Many old engines when rebuild used acheapersolution a slotted skirt. that allowed for theexpansion. Ifyou use the original style pison you should be alright. Some folks are now using pistons from modernengines.There are many to choose from,mostly from the small block chevy orfords. Youneed to know the bore size (3.875 stock) that will clean upyourcylinder walls and then check out the parts catalogues to find asuitable match.The slipper skirt used on the V8 pistons makes nodifference tothe application. Weight is a small problem but not at the slow speedsthe Aruns. Compression ratio however does matter. Be sure to check out thewrist pinto piston crown height. The piston should be flush to veryslightly abovethe cylinder head deck at TDC. Be certain it will not touch the head. Alittlemodeling clay placed on the piston and with the head in place turn theengineover. (no, not upside down
Original Posted By:-----Original Message-----
) remove the head and cut the clay inhalf andview the thickness. This will be your piston to head clearance. Wristpins sizescan be matched by using thicker rod bushings.Hope this isn't too confusing John Mc
Original Posted By: Mike Lund
What kind of pistons do you 'A' guys you when you rebuild?Richard===My homepage: http://www.AirCamper.org/w3builder....Oh that I had wings like a dove! for then would I fly away, and be at rest.-Psalm 55:6---------------------------------------------------------Visit www.AirCamper.org - A Low 'n Slow Online Community!---------------------------------------------------------____Free instant messaging and more at http://messenger.yahoo.com________________________________________________________________________________
Pietenpol-List: Re: 'A' pistons
Richard There are two choices for pistons of the A variety. Ford always usedwhat are refered to as "cam ground" pistons. They have a symetrical camshape when cold and expand alond the wrist pin to become cylindricalwhen at operating temp. Many old engines when rebuild used a cheapersolution a "slotted" skirt. that allowed for the expansion. If you usethe original style pison you should be alright. Some folks are now using pistons from modern engines. There are manyto choose from,mostly from the small block chevy or fords. You need toknow the bore size (3.875" stock") that will clean up your cylinderwalls and then check out the parts catalogues to find a suitable match.The "slipper skirt" used on the V8 pistons makes no difference to theapplication. Weight is a small problem but not at the slow speeds the Aruns. Compression ratio however does matter. Be sure to check out thewrist pin to piston crown height. The piston should be flush to veryslightly above the cylinder head deck at TDC. Be certain it will nottouch the head. A little modeling clay placed on the piston and with thehead in place turn the engine over. (no, not upside down
) removethe head and cut the clay in half and view the thickness. This will beyour piston to head clearance. Wrist pins sizes can be matched by usingthicker rod bushings.Hope this isn't too confusingJohn Mc-----Original Message-----
Original Posted By: John R Bayer
Hi Richard:Some go to Egge Machine in SO. Cal. I think they are on the Internet. Or check out the "Secrets of Speed Society" homepage, or the 4-Ever-4club, if they have one. I think you can use 283 Chev. pistons, but notsure what rods.John Bayer writes:>What kind of pistons do you 'A' guys you when you rebuild?>>Richard>===>My homepage: http://www.AirCamper.org/w3builder>....Oh that I had wings like a dove! for then would I fly away, and be >at rest. -Psalm 55:6>--------------------------------------------------------->Visit www.AirCamper.org - A Low 'n Slow Online Community!>--------------------------------------------------------->____>Free instant messaging and more at http://messenger.yahoo.com>________________________________________________________________________________
