Pietenpol-List: Taiwheel spring
Does anyone know the John Deere part number for the tailwheel spring?I have been searching BPA newsletters and archived e-mails to noavail.Alternative suggestions accepted.Thanks, Greg Cardinal________________________________________________________________________________
Pietenpol-List: Re: Taiwheel spring
Original Posted By: stephen s la bash
Hi Greg,>Does anyone know the John Deere part number for the tailwheel spring?>I have been searching BPA newsletters and archived e-mails to no>avail.>Alternative suggestions accepted.Its been a few months since I looked into this, but I seem to recall that a company called "Century Spring" had a couple of compression springs in stock that closely matched the spring specified in the plans. I have not yet gone so far as to ask for a price. If you do, and there's anything suitable, please let us all know. The URL that I've pasted below allows you to specify various spring parameters (length, diameter, spring constant...). If you input some broad ranges for these quantities that generally match the piet tailspring, you get a list of the parts they manufacture. http://www.centuryspring.com/newonlinec ... lt.aspHope that helps.--Peter________________________________________________________________________________
Original Posted By:> Greg Cardinal
The part# is T143444 $13.80 Canadian as of Sept.97Doug
Original Posted By: "BELLISSIMO, DOMENIC"
Greg, I have the part number at home. If you don't get a reply, let meknow and I will get it to you.________________________________________________________________________________
> Taiwheel spring
> > Does anyone know the John Deere part number for the tailwheel spring?> I have been searching BPA newsletters and archived e-mails to no> avail.> Alternative suggestions accepted.> > Thanks, Greg Cardinal________________________________________________________________________________
