Original Posted By: kyle ray
Hey group, would anyone know if it would be agood ideal to double the capstrip on the ailerondirectly aft the hinge crevise, (bottom)sand offor cut out the section that blunts out into the airstreamwhen the aileron is in the most downward position? By letting the aileron droop down and markinga line then cutting out excess material seems that it would stop some adverse yaw? yaw! 1>would doing this affect the airfoil in level flight? 2>would it be worth the trouble? 3.what would be any draw backs?________________________________________________________________________________
Pietenpol-List: Re:shaving the aileron
Pietenpol-List: Re: shaving the aileron
Dave,Where in S.W. Missouri do you live? I sometimes make it over to N.W.Arkansas in my Maule andwould like to go for a ride in a Piet.Gary WoodbridgeDavid Atnip wrote:> Hi Russell, Hope your Piet is coming along. For the rest of the> discussion group. I have been setting back and reading all your comments> and enjoying. I live in S.W Missouri and finished building my Piet in> 96. I now have almost 100 hours on it . It is built to Piet plans,> except I removed the rudder bar and installed rudder pedals, which i> really like. I have a Cont. 0-200 also installed. I would like to hear> from you all on how your (flying Piets) handle in turbulent air? my> experience in Light planes is small. I had about 12 hours in a cub to> get my tailwheel endorsement. In smooth air it flies like a dream.> Anyway your comments would be appreciated.. Dave>> kyle ray wrote:>> > Hey group, would anyone know if it would be a> > good ideal to double the capstrip on the aileron> > directly aft the hinge crevise, (bottom)sand off> > or cut out the section that blunts out into the airstream> > when the aileron is in the most downward position?> > By letting the aileron droop down and marking> > a line then cutting out excess material seems> > that it would stop some adverse yaw? yaw!> >> > 1>would doing this affect the airfoil in level flight?> > 2>would it be worth the trouble?> > 3.what would be any draw backs?> > hey David and Lenny!> >> >> > -________________________________________________________________________________
Dave,I am in Springdale,AR sometimes (family reunion end of this month) and I makeit over toBatesville,AR everyonce in awhile. Where is Aurora Airport?GaryDavid Atnip wrote:> I keep my Piet at the Aurora Airport..Where in N.W. Arkansas do you visit?>> Gary Woodbridge wrote:>> > Dave,> >> > Where in S.W. Missouri do you live? I sometimes make it over to N.W.> > Arkansas in my Maule and> > would like to go for a ride in a Piet.> >> > Gary Woodbridge> >> > David Atnip wrote:> >> > > Hi Russell, Hope your Piet is coming along. For the rest of the> > > discussion group. I have been setting back and reading all your comments> > > and enjoying. I live in S.W Missouri and finished building my Piet in> > > 96. I now have almost 100 hours on it . It is built to Piet plans,> > > except I removed the rudder bar and installed rudder pedals, which i> > > really like. I have a Cont. 0-200 also installed. I would like to hear> > > from you all on how your (flying Piets) handle in turbulent air? my> > > experience in Light planes is small. I had about 12 hours in a cub to> > > get my tailwheel endorsement. In smooth air it flies like a dream.> > > Anyway your comments would be appreciated.. Dave> > >> > > kyle ray wrote:> > >> > > > Hey group, would anyone know if it would be a> > > > good ideal to double the capstrip on the aileron> > > > directly aft the hinge crevise, (bottom)sand off> > > > or cut out the section that blunts out into the airstream> > > > when the aileron is in the most downward position?> > > > By letting the aileron droop down and marking> > > > a line then cutting out excess material seems> > > > that it would stop some adverse yaw? yaw!> > > >> > > > 1>would doing this affect the airfoil in level flight?> > > > 2>would it be worth the trouble?> > > > 3.what would be any draw backs?> > > > hey David and Lenny!> > > >> > > >> > > > -________________________________________________________________________________
